Fuse for theives
Old Jul 2, 2003 | 01:57 PM
BlackGS-R's Avatar
Default Fuse for theives
Could I pull an engine fuse to prevent theives from getting my car? If so can you tell me which one? I also have a aftermarket alarm so I don't want the fuse to disable it. Thanks any help would be appreciated.
Old Jul 2, 2003 | 04:12 PM
vteg's Avatar
New User
Default Re: Fuse for theives (BlackGS-R)
The backup fuse under the hood(7.5 amps from memory) will disable the ecu.
Old Jul 2, 2003 | 05:23 PM
BlackGS-R's Avatar
Default Re: Fuse for theives (vteg)
Is it in the black box with the rest of the fuses? What is it labled? Thanks for any help
Old Jul 2, 2003 | 05:49 PM
vteg's Avatar
New User
Yeah it is. It is labeled "backup"
It is to the rear of the box, close to the firewall under the hood.
Old Jul 2, 2003 | 05:55 PM
Xsi's Avatar
Xsi
Remember it will reset your ECU everytime you pull it
Old Jul 2, 2003 | 05:58 PM
BlackGS-R's Avatar
Default Re: (Xsi)
Ok what will reseting the ecu do? Sorry don't know too much about electronics. Thanks guys
Old Jul 2, 2003 | 10:32 PM
Xsi's Avatar
Xsi
When you reset the Ecu, it goes back to it's factory settings and you are supposed to let the car run for 5 minutes before driving while the ECU is learning the new settings.
If you just put the fuse back in and drive away it will learn different settings from if you let it idle for 5 minutes like you are supposed to.
This might do nothing, or it may make your car run funny and have increased fuel consumption.
roseda91
Aug 12, 2007 01:25 PM
mazik11
Dec 23, 2005 05:24 PM
E46Kid
Aug 16, 2005 07:58 PM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
SIK IN DA HED
Oct 27, 2002 08:42 PM
