ecu engine check light
Old Jan 10, 2003 | 05:00 PM
incognitoracerr's Avatar
Default ecu engine check light
my engine check light came on...did an ecu test and received 4 long flashes and 1 short which means a 41 code and the 41 is "primary oxygen sensor (heat)"...where is this sensor located?...how expensive is it?...and should i get it from the dealer or autozone?
Old Jan 10, 2003 | 05:29 PM
fukaintmuven's Avatar
Default Re: ecu engine check light (incognitoracerr)
its cheap... pepboys or sum sort of auto shop
Old Jan 10, 2003 | 05:38 PM
YeuEmMaiMai's Avatar
O2 sensor is usally in the exhaust header after all of the tubes merge together or if you have a V6/8 engine you may have one in each exhaust header just above the flange or in some cases one sensor after the Y pipe
turcasso
Jan 5, 2008 02:52 PM
matt6187
Jun 10, 2007 04:58 PM
Hybrid
Aug 17, 2003 08:55 PM
accord ex
Mar 25, 2003 10:10 PM
shauniewalnuts
Mar 8, 2003 02:17 PM
