E85 honda on 91 pump gas
Old Sep 6, 2017 | 01:32 PM
Roy Leyva's Avatar
Default E85 honda on 91 pump gas
Hi everyone
I just bought a civic turbo on E85 with Hondata S300, but i donīt have acces to E85 here. I can retune the car afr and timming for 91 gas but my biggest concern is if gasoline does not hurt the inyectors or fuel pump.
Thanks
Old Sep 6, 2017 | 01:50 PM
2x0's Avatar
2x0
10 Year Member
Default Re: E85 honda on 91 pump gas
Fuel system will be better off on 91 than e85
Old Sep 6, 2017 | 02:15 PM
Roy Leyva's Avatar
Stock fuel sistem suffer corrosion in E85, but no vice versa?
Old Sep 6, 2017 | 04:09 PM
2x0's Avatar
2x0
10 Year Member
I've never heard of any components engineered to handle e85 that aren't compatible with pump gas.
Old Sep 7, 2017 | 05:36 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Ethanol is essentially alcohol... which attracts moisture and is corrosive to aluminum. E85 is essentially 85% (typically between 65 and 85%)alcohol whereas 91 octane pump gas is a maximum of 10% (more commonly 6-8%). So, pump gas is at least eight times LESS likely to damage your fuel system and engine components. You will need to re-tune, but you won't have to worry about damage to your fuel system.
Old Sep 7, 2017 | 06:32 AM
Roy Leyva's Avatar
Great !!
jdmeg6118
Sep 30, 2012 12:57 AM
Bush-15
12
Sep 30, 2009 02:27 PM
hon2984
Jul 14, 2008 08:33 PM
Msnier85
Apr 9, 2007 04:24 PM
ProjectGreenLS
Sep 1, 2003 07:41 PM
