dyno plot question
Old May 7, 2002 | 08:50 PM
nfiedler3's Avatar
Default dyno plot question
hey i didnt get any answers from the ef forum:
how come on a dyno plot the hp peaks at a higher rpm when the torque curve seems to peek at a thousand or so rpm lower...excuse my stupidity
thanks
neil
Old May 7, 2002 | 09:21 PM
MikeSarr_GSR's Avatar
Default Re: dyno plot question (nfiedler3)
do you know for certain that what you are perceiving is actual behavior
of the same motor>?
Old May 8, 2002 | 07:20 AM
CHEETAH's Avatar
its all relative to the camshaft(s)
greg
Old May 8, 2002 | 07:25 AM
nfiedler3's Avatar
Default Re: dyno plot question (CHEETAH)
if an engine has more torque will it peak at a higher rpm?
Old May 8, 2002 | 07:45 AM
racerxadam's Avatar
it is because hp is proportional to rpm and torque. torque is the actual measurment that you get from a dyno and hp is calculated. the formula is
hprpm*torque)/5252. It is because of this relationship that at 5252 rpm hp=torque and then at higher rpm than 5252 hp>torque. If you look at dyno charts that have equal scales for hp and torque you will notice that they always cross very close to 5252 rpm
Old May 27, 2002 | 02:07 PM
Quick 200k Mile Motor's Avatar
Default Re: dyno plot question (racerxadam)
Yes, this is true. IF tq & hp are plotted at the same scale, they always intersect at 5.25 Also, after tuning a lot you will find that if you keep torque flat or rising in the highend, hp will also increase. A bad rod/stoke ratio engine will struggle to keep torque up even with higher cam profiles (vtec).
brian91accord
Aug 23, 2009 05:49 PM
Glove
Dec 30, 2008 07:31 PM
Phoenix1
Aug 29, 2005 08:47 PM
Toolman
Dec 27, 2004 12:03 PM
TrueNorthStar
Jan 28, 2003 08:07 PM
