dropped 1.5, need some advice...
Old May 7, 2002 | 09:34 AM
uNF$@#!'s Avatar
Default dropped 1.5, need some advice...
basically one of the members here told me 1.5 inch drop in the front, 1.3 drop in the rear from a stock height does NOT require a camber kit.
i know there will be some negative camber....but do you agree with him?
I will pay the extra 250 or so for the entire 4 corners if i need to...
what are your suggestions?!
this is on a stock integra type R
Old May 7, 2002 | 10:33 AM
oldbeefcake's Avatar
Default Re: dropped 1.5, need some advice... (00-0187)
go get an aligment, then you will know what you need to do.
Old May 7, 2002 | 12:09 PM
Ausmith's Avatar
It depends on what type of camber you want to run and what you are using the car for.
Up to -2degrees is fine in front.
In the rear I reccomend 0 to -.5 degrees.
Camber is not the real issue with lowering. In addition to picking up negative camber when lowering you also end up with a lot more toe-in. The added toe-in is what cause tires to wear quickly.
I use 1/32 to 1/16 toe-out in the front and 0 in the rear. This is my autocross/street alignment.
hatchetmansmybro
Sep 21, 2006 04:15 AM
es_squared
Apr 3, 2004 02:04 AM
SOHC_MShue
14
Sep 26, 2003 10:48 AM
JMD
Jul 16, 2003 05:56 PM
acatak
Apr 26, 2003 07:13 PM
