driving on empty tank
Old Jan 15, 2010 | 09:39 AM
  #26
delsolproblems's Avatar
Default Re: driving on empty tank
The best fuel pressures for LS Vtec depend on how it was built. Most stock B motors use 31-37 psi with the regulator vacuum hose attached and 40-47 psi with the regulator disconnected. Type R's and GSR's use fuel pressure that's 7-10 psi higher. If disconnecting the regulator vacuum hose raises the pressure about 10psi, then it should be working ok.
Old Jan 16, 2010 | 04:49 PM
  #27
trannyclaus.'s Avatar
I haven't read any of the other posts so I apologize if this has already been said buttttt your car problems could be due to:
1. the fact that your gas was so low, the junk that resides in the gas tank could have mixed in with what little gas was left thereby causing your issues.
or
2. your fuel pump could have gotten overheated/burned.
Hope that helps, and hope your car goes back to normal soon.
Old Jan 16, 2010 | 07:07 PM
  #28
xzodiackillerx's Avatar
a little water in gas will sit on bottom of tank . ... my guess is the spark plugs are worn out or wires/cap/rotor and making your car lose power. it will seem like a water in the gas situation. it wants to die under 2k rpm and misses under acceleration
crxaddikt
14
Jun 29, 2011 04:27 AM
XstouterX
Dec 18, 2005 07:56 AM
Good2b18b1eg
Feb 9, 2005 01:29 AM
E Swift
Dec 20, 2003 04:37 PM
RCautoworks
Dec 18, 2002 11:42 PM
