driving with a 3000 idle?
Old Nov 15, 2002 | 09:55 AM
metal-x's Avatar
Default driving with a 3000 idle?
basically after removing the JRSC and installing the stock mani, and reconecting everything back together my car is idling like a bitch at 3000 and I cannot figure out whats wrong with it can I get away with driving it to a shop near by?
Old Nov 15, 2002 | 10:13 AM
90da's Avatar
Default Re: driving with a 3000 idle? (metal-x)
Check your manifold gasket, may have a hole or something. I know leaking gaskets will give an idle surge. just an idea...
Old Nov 15, 2002 | 01:46 PM
non-VTEC's Avatar
sounds like leak........check the intake manifold gasket, throttle body gasket and throttle plate........
is there a check engine light on? check the code if there is......
Old Nov 15, 2002 | 02:08 PM
Lord Helmet's Avatar
Default Re: driving with a 3000 idle? (non-VTEC)
check your throttle cable(could be bindling or stuck). my car was idling at 2500-3000 RPM awhile back then I saw that my throttle cable was binding up, I replaced it with another oem piece and it went back to idle specs. I checked and tested my idle screw, the entire throttle body, iac, tps, and fast idle thermo valve just find out it was only the throttle cable acting up. hopes this help
Old Nov 21, 2002 | 05:35 AM
metal-x's Avatar
Default Re: driving with a 3000 idle? (sleeperciv)
turned out to be the TB gasket it wasn't in place properly thanks all for the help,
h-o-n-d-a
Aug 3, 2009 05:15 PM
95dc2teg
Sep 11, 2007 05:49 PM
go2sleep
Jun 27, 2006 01:36 PM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
2fknlo
Sep 13, 2004 01:15 PM
