surging problem
Old Apr 30, 2004 | 02:28 PM
suspendedHatch's Avatar
Default surging problem
At low throttle angles and cruising, my car experiences surging. Not enough to see on the stock tach but I imagine that it is rapidly accelerating 200RPM and then dropping, when it should be holding steady. I had this problem before I swapped the engine too! Only things that are the same are the distributer, exhaust mani, fuel pump etc. It's a different trans.
It also stumbles a little bit at idle and once in a while it will stall when coming to a quick stop. But otherwise the engine is very strong with excellent compression across the four cylinders.
Old Apr 30, 2004 | 10:25 PM
Default Re: surging problem (shaundrake)
bump
Old May 1, 2004 | 11:21 PM
No one can help? Im the only one who has ever had this problem? IM DOOMED!
Old May 1, 2004 | 11:39 PM
gumbii's Avatar
you should check the throttle body idle valve...
it's the valve that goes thru the throtle body, it's where anti-freeze enters the throttle body... i can't explain it... i could just fix it...
you should of searched or something...
Lokisdope
Dec 3, 2007 01:44 PM
handa
19
May 24, 2005 03:43 AM
SIK IN DA HED
Dec 24, 2002 06:06 AM
