DP-MPFI conversion help!!!
Old Jan 1, 2006 | 11:25 AM
og_hatch_90's Avatar
Default DP-MPFI conversion help!!!
i have a 90 civic STD 4 speed manual hatchback (d15b1 engine code). i need some help by tomorrow afternoon so please answer or link me to answers or something, anything you can do would be much appreciated.
i want to convert my car over to multi point fuel injection, i have the parts to do so but i dont know if they will work. the parts i have are:
1. DOHC ZC distributor from a 90 crx in japan
2. D16A1 wire harness from an 87 or 88 integra
3. PR4 ECU from a 90 integra
4. Injector resistor box from a 91 civic Si
5. Intake manifolds from a DOHC ZC and a D16A1
i need to know if all of this will work with my motor (direct bolt up) the main things i am concerned with are the distributor and wire harness.
i also have an Si tranny, all i need to know is if i have to change anything to bolt it up to my motor, like linkage, or shifter assembly. let me know something ASAP, im planning on pullin my motor out tomorrow, thanks.
Old Jan 1, 2006 | 08:38 PM
Crx88dohc's Avatar
Default Re: DP-MPFI conversion help!!! (og_hatch_90)
You also need the circle plug for the dist.(dx has a square one) 2 Small pins for the ecu, you need to add two, wire to wire in all the injectors + resistor box, PM6 ecu is better to run. Are you in Ca? If you are e-mail me. I do the Dpfi to Mpfi all the time.
Old Jan 1, 2006 | 09:04 PM
Default Re: DP-MPFI conversion help!!! (Crx88dohc)
na, im in NC..way off..haha. i would send it to you but it would take too long..its my only car..
pec pec
Jan 26, 2006 06:49 AM
dangvernhead
Oct 24, 2004 08:53 PM
ProtegetypeR
Mar 25, 2004 03:38 PM
Fototek7
Jul 3, 2002 04:44 AM
ICC96INTEGRA
Jun 18, 2002 07:27 AM
