Don't feel the vtec on my set up
Old Mar 27, 2006 | 02:37 PM
allmotorchick's Avatar
Default Don't feel the vtec on my set up
I just made my 95 integra ls/vtec i just dried hookng up the vtec but it does not feels like it ingages here is my set.I am using the ls obd1 harness runninig 2 wires to the ecu a p72 gsr obd1 but i did not hook up a knock sensor can that be the problem..
95 ls block
2000 gsr head
gsr obd1 dizzy
ls obd1 harness
no knock sensor
THANKS FO RTHE SPACE
Old Mar 27, 2006 | 04:47 PM
DelSeeYa's Avatar
Default Re: Don't feel the vtec on my set up (allmotorchick)
did u check your CEL's and see what codes your coming up with? if u have a code for Knock Sensor (23 i think) than that's ur prob, because without a knock sensor to serve it's purpose VTEC will Xover but the car will bog out so much you won't feel a think, too much knock in engine. hook up the knock sensor and that should solve your problems
Old Mar 27, 2006 | 05:30 PM
so lazy's Avatar
Default Re: Don't feel the vtec on my set up (DelSeeYa)
I gotta disagree with you on that delseeya... sorry but i've had a KNOCK SENSOR CEL on my ls'vtec it was fine it still engaged... Try checking your wiring and as for the knock maybe delseeya's right i don't know but i've had a KNOCK CEL my vtec still worked... you can easily mount your knock sensor like under your ALTERNATOR bracket...
IF you would like i could give you the wiring that you should have your vtec ran to and your pressure switch... just hit me up your car model..
Old Mar 27, 2006 | 06:30 PM
Default Re: Don't feel the vtec on my set up (dc2-guy)
What kind of ecu were you runnig without the knock sensor..
Old Mar 27, 2006 | 06:59 PM
so lazy's Avatar
i was running a p72 reason for being was because of the 2nd butterflies.. then i swapped to a p28 due to skunk2 manifold...
Old Mar 27, 2006 | 07:04 PM
92GSR HB's Avatar
I had a knock sensor problem before It would engage, but would bog itself down terribly. I agree with DC2-guy check ur cels and see what codes ur throwing
Old Mar 27, 2006 | 07:12 PM
so lazy's Avatar
Only thing i can think of for you is speed sensor i think if speed sensor(on the tranny) is messed up your vtec will not engage(had this problem with my gsr).. also wiring like i told you before if you would like i can look in the books at honda and i'll give you the right wiring(ecu pinouts) for the vtec and pressure switch..tell me what kind of car you got.
also if you say your not feeling vtec its probably cause its kicking in at 4500 due to its a p72 and it laggs til like 5800 when the 2nd butterflies open up.... i dunno listen to it dont feel it lol... you can tell if vtec hits or not you dont have to feel it..
Old Mar 27, 2006 | 07:20 PM
so lazy's Avatar
i'm sorry i just read your post lol.... i missed that your car is a 95 integra... i'll get you the pin outs as soon as i can..
Old Mar 28, 2006 | 04:35 PM
DelSeeYa's Avatar
Default Re: (92GSR HB)
92gsrhb i agree, cuz the same thing happened with my firnds ls/vtec when we did it, it would hit vtec and u'd hear and feel it tiny bit but not much due to once it got past vtec it'd bog itself to all hell, lol, i taped and rethreaded the upper alternator bolt that goes to the block and stuck a knock sensor in and that ls/vtec hatch ran it's lil hind off.
Old Mar 28, 2006 | 06:03 PM
so lazy's Avatar
maybe this problem is fixed!
Old Mar 28, 2006 | 06:32 PM
Thanks guys
I looked at all the wiring the way i did it it look good to me..
I will try to hook up the knock sensor and try a p28 this weekend and i will let you know what happens...
Old Mar 28, 2006 | 07:08 PM
so lazy's Avatar
np
Old Mar 29, 2006 | 09:13 AM
WhiteHB15LSD's Avatar
Forsure you need the knock sensor in it. Look up your CEL codes and if there is a code for one, you need it.
Old Mar 29, 2006 | 01:13 PM
tequilakid's Avatar
Default Re: (WhiteHB15LSD)
I disagree with all of you, I have a knock sensor cel, and VTEC still engages perfectly. This is with a stock p61, on a stock B17a
Edit: Also it doesn't bog once VTEC is engaged.
Old Mar 29, 2006 | 02:01 PM
so lazy's Avatar
Default Re: (tequilakid)
I dont know what your talking about ALL OF YOU... but i did say that VTEC will engage...
Old Apr 4, 2006 | 09:32 AM
Default Re: (dc2-guy)
I finaly got the vtec to come but does not feal strong.I guess i was used to my hatch with a built motor...
thanks everyone
toyotat100
Oct 15, 2014 07:57 PM
huckaboo
Dec 4, 2009 10:34 AM
xtreme-customz
Jan 6, 2006 05:09 PM
slayersluck
Dec 30, 2004 06:00 PM
clean99teg
Sep 21, 2002 05:43 PM
