Does this look normal? (56K maybe??)
Old Sep 22, 2004 | 07:13 AM
Audi RS4's Avatar
Lover
Default Does this look normal? (56K maybe??)
This is my throttle body off of a B16A, should it have that much carbon build up on it?
Old Sep 22, 2004 | 07:42 AM
hondaguyef's Avatar
Default Re: Does this look normal? (AK1200)
Give some more info on it. (last cleaning, year, etc.)
If it hasn't been cleaned since 1989 I'd say it looks pretty good
Phil
Old Sep 22, 2004 | 07:43 AM
Audi RS4's Avatar
Lover
Default Re: Does this look normal? (hondaguyef)
it's a 95 JDM b16a, never been cleaned by me. I've owned the motor for two years.
Old Sep 22, 2004 | 07:48 AM
Used2beAb16's Avatar
looks good to me
Old Sep 22, 2004 | 10:21 AM
93lsd's Avatar
looks normal just use some carb cleaner and slap it back on.
Old Sep 22, 2004 | 12:46 PM
hondaguyef's Avatar
Default Re: (93lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote">looks normal just use some carb cleaner and slap it back on.</TD></TR></TABLE>
word.
Old Sep 22, 2004 | 01:55 PM
_BEN_'s Avatar
What are your intake valve clearances set at? If they are set too tight some combustion gasses will get pushed back int the IM. All of that stuff is passing by your injectors too so check and see if those are clean.
The pic you hosted looks normal from what I have seen, so dont panic. Even the back of my tb plate looks like that.
Old Sep 23, 2004 | 06:11 PM
Audi RS4's Avatar
Lover
Default Re: Does this look normal? (_BEN_)
the last time i did a valve adjustment i set them to the high side of the spec.
Old Sep 23, 2004 | 10:38 PM
@ries's Avatar
Doesn't look too bad... I've seen worse.
Old Sep 24, 2004 | 12:41 AM
honda_power69's Avatar
Seen worse here too, just clean it up a little
Old Sep 24, 2004 | 01:51 AM
Xsi's Avatar
Xsi
Looks normal. Clean it up and get a catch can, it'll still crud up but not as fast
MSchu
Honda Motorcycles
39
Sep 16, 2005 05:25 PM
TyCooley
Nov 19, 2004 07:18 PM
R you serious
Apr 22, 2004 02:55 PM
Ants
Apr 11, 2004 09:41 PM
Mario
34
Aug 10, 2003 01:59 PM
