Does Head Gasket Sealer Really Work?
Old Jan 10, 2013 | 08:14 PM
netplaceus's Avatar
Default Does Head Gasket Sealer Really Work?
Okay, I am in a situation where I do not have the time or the space for a while to repair a bad head gasket in my 1988 Honda Civic DX.
It still runs for now, but there is some oil in my cooling fluid and some times the engine misses a lot until the car gets hot.
Anyway, I would love to hear your experiences with head gasket sealers.
Do any of them work, which ones are best or do you think they are mostly a waste of money?
Thanks in advance for your thoughts!
Old Jan 10, 2013 | 10:24 PM
JuicedUpRice's Avatar
Default Re: Does Head Gasket Sealer Really Work?
Im just gonna say it..
Save yourself from disaster,do not use that ****.
ive used it when i was a younger noob,and that **** just causes idle and coolant issues down the road,just when you think everything is fine.even after a gasket swap.it just gunks up in EVERYTHING!
a head gasket swap could be done in an hour or two if youre familiar with it..
Old Jan 10, 2013 | 10:29 PM
Fliptard's Avatar
Don't use it, Get a new headgasket and take what, maybe 4 hours? to change it. They aren't that hard. I did one once and i didn't know a frackin thing about hondas and it took me less than 4 hours.
Old Jan 11, 2013 | 02:41 PM
fcm's Avatar
fcm
Old Fart
X3, it's a quick fix that does not work well and will only end up costing you more money and time later. 94
Old Jan 12, 2013 | 12:14 AM
hwyix's Avatar
I agree with everybody else.
That being said, when you do a coolant flush on Subaru they give you some magic chit to add to the coolant. Subaru are known for head gaskets the magic stuff is for the head gaskets.
Subaru OEM Coolant System Conditioner - Genuine Subaru SOA635071
http://www.fcpimport.com/products/su...FYl7QgodTF8ASg
Description
Subaru of America, Inc. (SOA) has determined that over time, vehicles may develop small external coolant leaks at engine cylinder head gaskets. This is the result of normal expansion and contraction of engine components caused by the heating and cooling of these parts. To prevent cylinder head gasket leaks from developing or to correct existing leaks.
Old Jan 13, 2013 | 04:56 PM
Ratt731's Avatar
I agree with everyone, from personnal experience. I used it back when I was 17 or 18 and it worked for a very short time. Gasket ended up blowing out worse then before and being undrivable (solid white smoke screen). Save yourself the time and just change the gasket now. Also like previously mentioned it does gum up other areas in the coolant system and can cause further problems down the road.
Old Jan 14, 2013 | 02:00 PM
jdmh22eg2's Avatar
Blue devil (autozone and advanced auto sells). WONDERFULL stuff works wonders when done 100% correctly
Old Jan 16, 2013 | 02:56 PM
93CRX-Del SOl's Avatar
just buy a new head gasket... don't bother with that pasty crap
Old Jan 17, 2013 | 09:37 PM
raverx3m's Avatar
any kind if sealer is just that. it seals more than it supposed to
i had one car with the coolant sealer
it clogged all the small coolant lines had deposits in every coolant passage
deposits on the bottom of cylinder passages
clogged FITV and IACV completely
but somehow got lucky and didnt clog the heater core...
Old Jan 20, 2013 | 04:29 PM
tvaofir7's Avatar
Don't use it. I have a car where the previous owner dumped that crap in it. After a new radiator, thermostat, and head gasket it's finally good. That stuff clogs everything. Pulled the old head gasket off and a half inch thick paste was stuck on it all the way around. Had to flush out all coolant passages and clean the cylinder passages.
Old Jan 20, 2013 | 09:38 PM
myhonda99's Avatar
NEVER USE IT!!!!!!!!!!!!!!!
Old Jan 21, 2013 | 11:01 AM
netplaceus's Avatar
Thanks for all your replies. I took your advice, made the time and fixed it right!
Works great now. Here is a picture of the blown gasket, note huge missing sections near the coolant holes.
For now the car runs great again. I am at 265K, do ya think I will make 300K before I blow a ring or something else that requires an engine rebuild?
Old Jan 21, 2013 | 11:44 AM
raverx3m's Avatar
did you resurface the head and use leakproof honda metal headgasket?
Old Jan 21, 2013 | 01:00 PM
Ear'sEgFerio's Avatar
I have personally used myself Blue Devil in over 7 vehicles. Its done AMAZING work. I even used it on my 1999 BMW. This stuff does wonders and is 100% GURANTEED to NOT do any engine damage. I even made a bet with a buddy on his 88 Ef sedan that it would fix it or i would change the HG for free. Till the day i still havent heard the words HG come out his mouth lol
Old Jan 22, 2013 | 07:36 AM
netplaceus's Avatar
Yes. However, I decided not to go with the OEM Head Gasket from Honda. Even the Honda parts guy told me I could do better then the stock 1988 part.
I forget the name but it is a Multi-Layer Steel head gasket. Higher end, $140.00
bucks. Now there is a topic for a new thread. High end Multi-Layer Steel head gaskets, well worth the money or OEM good enough.
Old Jan 25, 2013 | 02:46 PM
2fast4uhonda's Avatar
Definently a no no!! I have problems in the past also using that crap
Old Jan 25, 2013 | 03:38 PM
nospaghetti's Avatar
I used it once on a toyota truck, there are multiple steps to using it. mix with warm water, drain system, add in sealer, rev to 1500 rpm or somethiing like that for 10 minutes. then drain, flush cooling system. and you have to wait 24 hours before filling it up. basically the stuff only goes in to seal and then its flushed out. Then you fill with coolant. i did it and it went for over 5 years with no issues. it prob depends on how bad your HG is. and how well you know how to do the job.
I had good luck on the Toyota truck, but on Honda's its so easy i just change the gasket and resurface the head.
Old Feb 3, 2013 | 07:31 AM
ayoitzmayo's Avatar
used it once and never again!
Old Nov 22, 2020 | 12:45 AM
headgasket's Avatar
Yes, head gasket sealers work as a permanent repair. Yet, since nothing is permanent we’d rather term it as “long-term” repair. The repair typically lasts at least 6 months (depending upon car condition). It’s a convenient solution and a quick DIY fix that’s better than a burdensome (expensive & tedious) part replacement. In case the leak Is major, the sealer may not be a permanent or suggested solution. In such a case, a complete replacement of the head gasket might be the only viable solution.
Learn More
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
Cho0se
Feb 24, 2020 02:59 PM
da_33
Jan 11, 2007 11:12 AM
mulin
Nov 3, 2004 09:25 PM
sleepyIntegra
May 24, 2004 11:14 AM
