Does anyone know how to reset the Maintenance light on the Integra???
Old Jun 18, 2002 | 09:22 AM
cinq's Avatar
Default Does anyone know how to reset the Maintenance light on the Integra???
My brake fluid was low..and the "brake" light came on..and the maintenance light too. After refilling the fluid..the "brake" light went away...and i still get the maintenance flashing after starting the car...and a 10 secs later..it goes away. Anyone know how to reset that? Thanks in advance.
Old Jun 18, 2002 | 10:09 AM
bruthaboost's Avatar
Default Re: Does anyone know how to reset the Maintenance light on the Integra??? (cinq)
To reset the check engine light pull the backup fuse from the under the hood fuse box. The reset the svc rec'd light, look for a push button over the right leg of the driver underneath the dash.
HTH
Old Jun 18, 2002 | 10:30 AM
Acronym's Avatar
I had the same problem...i know 98+ look at your gas pedal go to reach for it half way turn your hand around palm up...come back under the dash and there is a little white buttom its square just hit it once then re set your ecu.....hop out and do a start up!
if u want u can lay on your back and look under and u can see it but that probably only works for small people like me...
Old Jun 18, 2002 | 03:10 PM
MikeSarr_GSR's Avatar
Default Re: Does anyone know how to reset the Maintenance light on the Integra??? (Acronym)
hes not asking about the CEL.
the maintainence reset button is behind the steering column
to the right its a smooth button, press and hold it.
Old Jun 18, 2002 | 05:12 PM
96_GSR's Avatar
Default Re: Does anyone know how to reset the Maintenance light on the Integra??? (MikeSarr_GSR)
It's a little blue button underneath the dash. Turn the ignition to on, don't start it, and hold the blue button until the light stops flashing..done.
Old Jun 18, 2002 | 06:35 PM
cinq's Avatar
Default Re: Does anyone know how to reset the Maintenance light on the Integra??? (96_GSR)
Thanks guys for the prompt respond....
White button...Red button... Blue button...
so many to choose...Maybe i'll see the light at the end of the rabbit hole.
[Modified by cinq, 3:37 AM 6/19/2002]
Old Jun 19, 2002 | 10:05 AM
GM2000ITR's Avatar
New User
Nice & simple: to turn the maintenance required light off, locate the square button just under the driver's side lower dash(near your right leg). Hold that button for 5-10 seconds & you're done!
PatrickGSR94
Oct 7, 2015 01:55 PM
EvGaLee
Apr 2, 2011 09:14 AM
civic5483
Jan 19, 2007 05:18 PM
m.c.
May 2, 2006 08:59 AM
