Do I need to use phosphate free coolant?
Old Nov 7, 2002 | 06:28 PM
T_Rex's Avatar
Default Do I need to use phosphate free coolant?
I changed my coolant the other day and used this brand called Mototech. I thought they were all the same, but now I read here that I should have used Honda coolant. The Mototech stuff has phosphates. Should I change it again or is it fine? It's a B16 CRX.
Old Nov 9, 2002 | 12:35 PM
T_Rex's Avatar
Default Re: Do I need to use phosphate free coolant? (hondanut)
Old Nov 9, 2002 | 01:11 PM
DillHole's Avatar
I would use Honda coolant. THat way you don't need to worry about a seal going out as much or water pump, radiator, etc. I think last time I bought it at dealer it was about 10 or 12 bucks.
Old Nov 9, 2002 | 02:23 PM
ejprimo's Avatar
Default Re: Do I need to use phosphate free coolant? (DillHole)
i just use extended life prestone. its suppose to be silicate and phosphate free. saved 5 whole dollars by not going to the dealer.
Old Nov 9, 2002 | 05:00 PM
RotaryBzzz's Avatar
Default Re: Do I need to use phosphate free coolant? (ejprimo)
yeah, just check the ingredient list on the back. I found cheese-ball Target brand "Car and Driver" coolant was phosphate free...
Old Nov 10, 2002 | 12:31 AM
PyroVTEC's Avatar
New User
Default Re: Do I need to use phosphate free coolant? (RotaryBzzz)
Coolant? I'm running straight water + waterwetter!
Works only in LA though, with a garaged car...
Prestone extended life 50/50 works pretty well for coolant. They're the new red stuff, not the old green stuff...
Old Nov 10, 2002 | 12:47 AM
hanson said's Avatar
Default Re: Do I need to use phosphate free coolant? (PyroVTEC)
yikes!
i was under the impression that some of the ingredients from coolant were necessary. fill me in here.
i am well aware that water has better cooling abilities, as well as the purpose of the water wetter, but no coolant? fill me in.
Old Nov 10, 2002 | 10:58 AM
RotaryBzzz's Avatar
Default Re: Do I need to use phosphate free coolant? (hanson said)
coolant is usually called "anti-freeze" in other parts of the country besides LA. It lowers the freezing point of water when it's blended in. Coolant is also a corrosion inhibitor....makes it harder for rust to form in your radiator/engine cooling jacket passages.
Old Nov 10, 2002 | 11:40 AM
Kataku2K3's Avatar
Really you're going to want phosphate free coolant on anything that has an aluminum radiator.... I know Volkwagon and Mercedes are like this and they require you to use their coolant which is phosphate free because it won't clog the radiator.. For Honda I just use factory or Prestone...
[Modified by JDMspecEG6, 12:40 PM 11/10/2002]
Old Nov 10, 2002 | 10:41 PM
PyroVTEC's Avatar
New User
I was thinking of the corrosion part of the equation too. But there isn't much if any corrodable stuff in the cooling system, that I can think of. Water jackets are aluminum; the iron sleeves don't touch water... the head & block is Al. Water pump should not rust. Cross pipes (back of the blocK) are also aluminum.
Long story short: I'm in LA, car parked in garage. It won't freeze!
Old Jan 26, 2003 | 05:08 PM
T_Rex's Avatar
Anyone know for sure if Prestone is phosphate and silicate free.
Old Jan 27, 2003 | 10:59 AM
T_Rex's Avatar
Default Re: Do I need to use phosphate free coolant? (T~Rex)
Old Jan 27, 2003 | 08:47 PM
RotaryBzzz's Avatar
check the ingredients on the back. It would be reflected in the label.
Old Jan 27, 2003 | 08:53 PM
GSRrR's Avatar
Prestone is phosphate free. Well the green stuff is, I just checked.
Old Jan 27, 2003 | 09:42 PM
1SlowB16EF's Avatar
did you guys know that only a couple drops of soap is the same as a Redline water wetter!!!
Old Jan 29, 2003 | 11:09 AM
T_Rex's Avatar
Default Re: Do I need to use phosphate free coolant? (GSRrR)
Doesn't it need to be silicate free too?
importdude2000
Jun 4, 2004 02:08 PM
DXturbo
Sep 8, 2003 01:56 PM
T_Rex
Nov 9, 2002 06:21 PM
deviant1
Oct 24, 2002 07:25 PM
Duck Sauce
Nov 23, 2001 08:49 AM
