Do I Need a New Headgasket?
Old Feb 11, 2004 | 05:35 AM
vtecb20coupe's Avatar
B A N N E D
Default Do I Need a New Headgasket?
just wanted to know if i can use an OEM 81 mm headgasket on a 81.5 mm bore block? or do i need to look into either an 81.5 or 82 mm aftermarket hadgasket? thanks.
Old Feb 11, 2004 | 05:42 AM
B A N N E D
Default Re: Do I Need a New Headgasket? (vtecb20coupe)
also, i've been told that the stock gaskets are bored .020 over from the dealer. has anyone ever been able to measure the diameter to verify this?
Old Feb 11, 2004 | 08:52 AM
RyanEJ8's Avatar
I used the stock gasket with my .020 overbore. Then again, I blew the gasket with a 100 shot, but my tuner said that the blown head gasket and the melted plug were from a lean onset of the nitrous.
Old Feb 11, 2004 | 09:14 AM
B A N N E D
Default Re: Do I Need a New Headgasket? (RyanCivic2000)
hmmm....anyone else before i have to spend $80+ on a cometic?
Old Feb 11, 2004 | 12:22 PM
RyanEJ8's Avatar
I ran fine for 6 months with the stock headgasket though, N/A. Revved it up hard alot and it never had any problems until the nitrous.
Old Feb 11, 2004 | 12:54 PM
Rtype16's Avatar
Stock head gaskets are great, but if you don't have head studs or replace the factory bolts when you take the head off you will have problems.
Old Feb 11, 2004 | 12:59 PM
B A N N E D
Default Re: Do I Need a New Headgasket? (Rtype16)
i'll be using aebs studs.
Old Feb 12, 2004 | 07:13 AM
B A N N E D
does anyone know if oem honda makes a .020 headgasket vs the .25 over headgasket?
Freshdot
Sep 20, 2010 10:41 AM
hamizle
Dec 1, 2009 04:55 PM
timm099
Jan 15, 2007 08:52 AM
flip1199
Jun 23, 2005 09:33 AM
BoostedH23a1
Nov 7, 2002 10:58 PM
