do i need a different ecu in my 91 si with a d15b?
Old Dec 12, 2004 | 03:58 PM
r1lorenzini's Avatar
Default do i need a different ecu in my 91 si with a d15b?
i have a 1991 honda civic si. i recently purchase a d15b. do i need a different ecu or will my stock ecu work?
Old Dec 12, 2004 | 06:15 PM
quik1's Avatar
Default Re: do i need a different ecu in my 91 si with a d15b? (r1lorenzini)
You should be fine with that ecu, there's not enough of a difference in engine size to make a big difference.
Old Dec 12, 2004 | 06:55 PM
RedlinedVTEC's Avatar
I've done a few swaps like this for people just needing a fresher motor. Just reuse your current intake manifold and distributor and you should be fine. You will have to wire up the fan switch but other than that it is a direct bolt in.
Old Dec 12, 2004 | 10:04 PM
Default Re: do i need a different ecu in my 91 si with a d15b? (RedlinedVTEC)
what if the motor has a intake and distributor on it? what fan wire do i need to wire up?
bcumbie
Engine Management and Tuning
Mar 16, 2012 08:49 PM
nmhuntr
Sep 30, 2009 05:56 AM
luisda4th
Feb 26, 2008 04:19 AM
CRIX IN 13
Dec 1, 2003 09:28 PM
