DIY Tachometer LM3914-N
Old Dec 11, 2010 | 01:49 AM
majdi's Avatar
Default DIY Tachometer LM3914-N
Hi, i just complete build tach light, but fail to add some blinking function using NE555 ic.
http://www.youtube.com/watch?v=fAN2w...layer_embedded
can it tap out from led dot signal to NE555 circuit so i can get blinking LED as shift light.
Old Dec 11, 2010 | 03:29 AM
majdi's Avatar
Default Re: DIY Tachometer LM3914-N
here the diagram..
Old Dec 11, 2010 | 08:26 AM
majdi's Avatar
Just think tu tap NE555 circuit but fail, any suggestion anyone. THIS DIAGRAM WORK FOR TACH ONLY
Old Dec 13, 2010 | 09:04 AM
majdi's Avatar
http://www.youtube.com/watch?v=yfEVGzpRRXg
Done ;P simple circuit
Old Apr 25, 2011 | 12:11 AM
ridelperez's Avatar
Nice project
Old Apr 25, 2011 | 01:14 AM
TypeRMOBBiN209's Avatar
thats actually pretty cool
Old Apr 25, 2011 | 01:22 AM
blackedEk's Avatar
ha kinda is cool
Old Apr 25, 2011 | 01:48 AM
Natural Aspirations's Avatar
Looks great! Thanks for sharing.
A boost gauge referenced off the map would be interesting as well.
Old May 5, 2011 | 11:53 PM
majdi's Avatar
Originally Posted by ridelperez
Nice project
Hey here the project circuit :D hope you enjoy it
1 x LM2917N
2 x LM3914
1 x 7809
21 x LEDs
1 x 1N4007
1 x 1N4148
1 x Zener diode 12 Volts
1 x 220 Kohm variable resistor
2 x 1 Kohm
3 x 10 Kohm
1 x 22 Kohm
1 x 2.2 Kohm
1 x 470 ohm
Electrolytic Capacitors:
1 x 470 microFarad 25 Volts
1 x 2.2 microFarad 16 Volts
Polypropylene Capacitors:
3 x 100 nanoFarad
1 x 47 nanoFarad
1 x 1 microFarad
Old May 5, 2011 | 11:56 PM
majdi's Avatar
Here the circuit and adjusted rev light i using transistor to power up blinking circuit
Old May 6, 2011 | 12:27 AM
make me one
Old May 6, 2011 | 07:07 PM
joaodh's Avatar
good night, you know tell me if it is possible to put this circuit in a karting 2
times? input signal comes from the coil, which gives current to the spark plugs?
Old May 12, 2011 | 03:16 AM
majdi's Avatar
Here you can refer it from this manual, this project installation same with product on manual.
yES input signal from -Coil that gives current to spark plugs.
File Type: doc
Old May 12, 2011 | 03:21 AM
majdi's Avatar
Originally Posted by TypeRMOBBiN209
make me one
Hey if you interested, i got the PCB drawing in ExpressPCB , you can etching and solder up those component your self
Old May 13, 2011 | 01:45 AM
pcguy760's Avatar
Wow I can't believe how old the 555 timer ic and 3914 bargraph driver is and yet it is still so versatile to this very day! Good job btw
Old May 13, 2011 | 07:35 AM
NVturbo's Avatar
O.G. triple O.G.
looks interesting. Light up the RPM numbers and it will be set.
Old Mar 21, 2022 | 04:30 AM
Spa's Avatar
Spa
I am interested in the PCB drawing to make one of these. I would appreciate a copy please.
k3vin337
Mar 9, 2008 07:16 PM
jl21ah
May 4, 2004 10:51 PM
kingSfit
14
Feb 10, 2004 04:48 PM
GTlvr82
18
Mar 21, 2003 02:23 PM
civicmark
Jul 5, 2002 03:06 PM
