DIY fuel injector cleaning???
Old Jan 9, 2003 | 03:42 PM
SOHCMAN's Avatar
Default DIY fuel injector cleaning???
Isnt this just ultrasonic cleaning with a mix of alcohol and water? or is there more to it? Because I have a small ultrasonic cleaner.
and when Honda says they can "clean fuel injection and induction system" what else if anyhting are they doing besides th injectors??
Thanks guys
sohc
Old Jan 9, 2003 | 04:22 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: DIY fuel injector cleaning??? (SOHCMAN)
iono about honda cleaning, but i read this procedure somewhere. get a bottle of Techron, take a can of tuna, eat the tuna, punch four holes in the bottom of the can big enough for the tip of the injector, place them in the can, put the can in the cleaner and pour techron just to cover the can. shake vigoursly for as long as needed. you can also rig up something to pulse the injectors while they soak.
stan
Old Jan 9, 2003 | 07:28 PM
integra6650's Avatar
Default Re: DIY fuel injector cleaning??? (90crxsi)
what if you dont like tuna?
Old Jan 9, 2003 | 07:51 PM
Sonny's Avatar
Default Re: DIY fuel injector cleaning??? (integra6650)
Tuna prepares you for a lot of greater things in life.
Sonny
Old Jan 10, 2003 | 09:33 AM
SOHCMAN's Avatar
Default Re: DIY fuel injector cleaning??? (Sonny)
So pretty much you have to you have to use a cleaner of some sort. What about new injectors? Stock? Bosch?
thanks
sohc
Old Jan 10, 2003 | 11:36 AM
Perfectionist's Avatar
Don't waste your money. Honda injectors are pretty darn good and rarely need to be replaced or cleaned out of the car, unless you fill up at the worst gas station in town. You know, the one with the hole in the underground tank that lets water and mud in. If you have to, use something like Chevron's Techron in the fuel tank.
Old Jan 11, 2003 | 03:41 PM
SOHCMAN's Avatar
Thank you for all your replies, anyone else?
c
Old Jan 11, 2003 | 06:33 PM
MattG's Avatar
New User
c
I have seen this done but I don't know if it applies to Hondas. You can get a can of cleaner that will actuall run the car. You disconect the fule pump (fuse) and hook a special valve to the fule pressure (something). The can connects to the fule system with special fittings for cars (you need a kit with all the fittings). The car runs off this special cleaner for about 10 minutes. Then you just unhook everything and put the fuse back in. Voala...clean injectors.
Old Jan 11, 2003 | 09:07 PM
Nameless RB26's Avatar
Sonny
Word up!
Old Jan 12, 2003 | 12:35 AM
Drag_Dc2's Avatar
Default Re: DIY fuel injector cleaning??? (Nameless)
MattG,
The system is quite expensive i believe its about 400 bucks...I believe the system can be purchased from OR?? Not exactly sure what the company name is but its a standard fuel injection cleaner.
A few of my friends who attend automotive trade school have done this to their cars since they have access to the tool at school and said it helped out considerably. Dunno if its worth 400 though
Old Jan 12, 2003 | 02:30 AM
evo's Avatar
evo
New User
Default Re: DIY fuel injector cleaning??? (DragDc2)
I actually took the injectors out and spray the carb cleaner, did I Fcxx the injectors, I've not yet put that back on.
sgull
Jun 25, 2013 07:48 AM
Mr.Highlife
Nov 15, 2009 04:29 PM
crj_lll
Mar 30, 2006 09:42 AM
SOHCMAN
Jan 10, 2003 08:53 AM
