distributor troubles.
Old Jul 9, 2013 | 05:59 PM
jarmand's Avatar
Default distributor troubles.
I have a 94 Integra with an OBD2 GSR head on it. The people before me made the OBD2 dizzy work on the car put it is throwing a check engine light. My question is does anyone know of a reputable aftermarket distributor manufacture. OEM ones are hard to find and expensive. IF I could get some info on the pitfalls of some aftermarket ones that would be great.
Old Jul 9, 2013 | 06:01 PM
jarmand's Avatar
Default Re: distributor troubles.
The wiring is all good also and it is throwing the code cause of the magnets in the distributor. forgot code number.
Old Jul 10, 2013 | 11:28 AM
accorse07's Avatar
Your pretty sure its not the igniter or the coil? If so I would pick up a dizzy that needs a rebuild. 9 times out of 10 its a bad igniter or coil or both. Simply move your parts over.
I highly advise against the Taiwan/China aftermarket dizzies. Simply bad...tried one once due to a bind and the fork that attaches to the cam broke...
Old Jul 10, 2013 | 03:07 PM
jarmand's Avatar
Ya, I'm not a fan of the cheap stuff even though finding a stock dizzy can be pricey. the car runs great so I don't think its the ignitor. I just want the check engine light off and was wonder if there was a reputable aftermarket solution that wasn't MSD.
Old Jul 13, 2013 | 09:01 PM
WAUKEENEM1's Avatar
i have an oem dizzy from a 2000 civic si if you're interested.
Old Jul 14, 2013 | 08:14 AM
turbodcxbro's Avatar
Get us the actual error code and we can better diagnose your problem. There is no code for "bad magnets" in the dist...
Old Jul 14, 2013 | 08:58 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ need the code(s). 94
Migs19
Sep 7, 2016 12:32 PM
Ej8 d16
Jan 23, 2015 01:37 PM
harvinder
Dec 2, 2008 01:45 PM
Fat Chick Magnet
Jul 30, 2006 09:06 AM
g2man
Jun 9, 2006 10:07 PM
