Distributor shaft seals on Ebay!
Old May 3, 2007 | 12:27 PM
Mochanic's Avatar
Default Distributor shaft seals on Ebay! (Fixes oil inside distributor problem)
For those of you with oil inside your distributor... I found the hard to find distributor shaft seals for most all Honda distributors (22.5x12.5x5) which you cannot buy from the dealer nor local parts houses. (I couldnt even get it from a bearing/seal place anywhere in Houston since it was in half mm sizes)
You can replace this seal yourself with a few normal hand tools in less than 30 mins and save yourself a ton of money and headaches!
This guy can probably get you any other seals that you run across too!
http://cgi.ebay.com/ws/eBayISA...i%3D1
Vtec_India
Feb 15, 2016 10:15 PM
BAD AZZ ACCORD
Dec 26, 2011 08:11 PM
04silvep3
Dec 8, 2008 10:54 AM
WVhump
Acura TL, RL & ZDX
Mar 28, 2007 10:30 PM
Quade
Jun 13, 2003 07:16 AM
