distributor no spark
Old Feb 25, 2012 | 04:29 PM
mygoldeneg's Avatar
Default distributor no spark
solved
Old Feb 25, 2012 | 04:39 PM
turbohatch96y7's Avatar
Default Re: distributor no spark
Are you getting 12 volts to the distributor?
If not start there
Old Feb 25, 2012 | 06:51 PM
mygoldeneg's Avatar
If not start there
yes i am getting 12 volts
Old Feb 25, 2012 | 07:20 PM
Have you checked your grounds to the distributor and thermostat housing?
If 12v is getting to your primary coil check your ground paths.
Have you put a spark tester on the spark plug wires?
I don't have the schematic in front of me for the dizzy, what year is the car and harness setup?now that I reread your first post its most likely a ground issue if all your parts work on another car unless its the ecu pins or harness side pins.
Old Feb 25, 2012 | 07:27 PM
mygoldeneg's Avatar
all the grounds are fine they were all checked with a light tester and voltmeter
Old Feb 26, 2012 | 01:33 AM
Have you checked for the input signal to the ignitor?and continuity to the ecu from the distributor?
Old Feb 26, 2012 | 06:33 AM
mygoldeneg's Avatar
yes that was stated in the first post
Old Feb 26, 2012 | 09:50 AM
civickiller's Avatar
timing belt still good? no spinning of cam=no spark
Old Feb 26, 2012 | 10:13 AM
fcm's Avatar
fcm
Old Fart
You said you have power to the distributor assembly, is that with engine cranking and not just when ign. is turned on?
Also, MM&Y of car and any mods/swaps would help. 94
Old Feb 26, 2012 | 11:43 AM
No where in the first post is it stated.
Good luck with the little bit of info your giving this is a guessing game.
Old Feb 27, 2012 | 08:01 AM
mygoldeneg's Avatar
ttt
Old Feb 27, 2012 | 11:25 AM
fcm's Avatar
fcm
Old Fart
Bumping your tread without answering questions is not going to help. 94
halocore
Jan 8, 2010 04:20 PM
808DA
Mar 26, 2009 05:24 PM
crxion91
Jan 19, 2008 12:35 PM
willsEK-HF
Feb 26, 2006 12:53 AM
CptCorN
Jan 17, 2005 06:33 AM
