Distributor isnt firing
Old Nov 18, 2002 | 02:32 PM
Anthonyl469's Avatar
Default Distributor isnt firing
OK. The engine is b18c5 and the car,harness, and ECU is 99 si. I hooked the harness up and no spark. The coil primary and negative are both getting 12V when the key is turned over, but when I take a plug wire and plug and try to get them to ground and spark all the coil does is lose all its voltage. No spark at all. I went to Honda and he said its prolly my firing mechanism..WTF is that?!..man this really sux..what could it be?
Old Nov 18, 2002 | 02:43 PM
D-Man's Avatar
Default Re: Distributor isnt firing (Anthonyl469)
this dont sound right,i dont think both sides suppose to get 12V but im not 100% sure either.
Old Nov 18, 2002 | 02:54 PM
Default Re: Distributor isnt firing (D-Man)
Yep they are both supposed to get 12V.
Old Nov 18, 2002 | 09:32 PM
salbaje's Avatar
check all grounds and wire for starter, etc. also fuse cover
Old Nov 19, 2002 | 05:58 AM
Desslok's Avatar
Default Re: Distributor isnt firing (PreloodDude)
igniter
Old Nov 19, 2002 | 07:23 AM
jdmcx's Avatar
its the icm you can use any honda one i am running a gsr head with a gsr housing and a 94 dx igniter and coil ect....
hope this helps
Old Nov 19, 2002 | 03:52 PM
Default Re: Distributor isnt firing (jdmcx)
Well is it the igniter for sure? Because that thing cost 150 bucks...how can i cehck and see if mines good?
Old Nov 19, 2002 | 04:40 PM
mugenracer's Avatar
if the ignitor is firing then your spark plugs should be covered in fuel as the injectors take their signal from the ignitor, so crank the engine a few times and pull one of the plugs and examine the electrode for wetness, if it is wet then the ignitor is working
Old Nov 19, 2002 | 05:48 PM
Default Re: Distributor isnt firing (mugenracer)
Funny thing you said that...My fuel pump wont even put out fuel pressure...you think thats my problem?
Old Nov 19, 2002 | 06:10 PM
Jdm91Teg's Avatar
double check all grounds. Have had a problems before that sound the same and it was just a ground not hooked up.
Old Nov 19, 2002 | 06:12 PM
Default Re: Distributor isnt firing (Jdm91Teg)
They are all hooked up. I have went over them numerous times.
Old Nov 20, 2002 | 07:16 AM
jdmcx's Avatar
pull the igniter out and check the resistance across it forgot which prong but if you got a manual it will tell you if the fuel pump is not coming on it could be the fuel pump fuse
gl89
Jan 17, 2019 08:57 AM
jakescakesz06
Jan 4, 2016 09:38 AM
Jaynik
46
Dec 4, 2013 05:29 PM
94GsRacer
Jan 14, 2003 06:39 AM
civicjunkie
Dec 14, 2001 03:56 PM
