distributor coil??
Old Jun 9, 2003 | 08:07 PM
methos713's Avatar
Default distributor coil??
i have an extra distributor from a b16 obd1, and when i did my motor swap..with the p28 ecu, we forgot to disconnect the knock sensor wire...the ecu burned, and was replaced by a p30, then the car wouldn't start. checked everything, and it was b16 distributor, replaced it w/ gsr dist. now i need to know where i can get a dist. coil to replace the b16 dist...and is it cheap or do i have to spend hella $$. also could it be that the dist. burned because of the ecu. also we drove the car for a while before the dist. went bad.
alperx
Jan 23, 2011 01:29 PM
1991ef8Sir
Apr 8, 2008 03:15 PM
X2BOARD
Aug 6, 2002 07:38 AM
