disconnecting battery?
Old Nov 19, 2007 | 08:31 AM
girliehonda's Avatar
Default disconnecting battery?
Is it safe to take off positive instead of negative while working on the car or in order to reset it? i notice one of my friend usually do it to his car because he said the positive side is easier to take off without a tool. so thats how he reset his motor all the time. so is it safe? i know most people disconnect it on the negative side. Overall its been buggin be because i was taught to take of the negative side.
Old Nov 19, 2007 | 09:42 AM
hatchling37's Avatar
Default Re: disconnecting battery? (girliehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by girliehonda &raquo;</TD></TR><TR><TD CLASS="quote">i was taught to take of the negative side.
You're correct. Don't take off the positive terminal, unless you plan on taking the battery out of the car. They require the same "tool" as they both have a 10mm nut on them. Just for your own edification, he's not resetting the engine, he's resetting the ECU.
Old Nov 19, 2007 | 02:56 PM
Perfectionist's Avatar
Removing either terminal will of course remove battery voltage fron the vehicle. The reason the negative is usually disconnected is to avoid shorting the positve terminal to ground if you accidently set a piece of metal in the wrong place or drop a wrench.
salandrew09
Welding / Fabrication
Oct 22, 2010 04:55 PM
Power Rev Racing
60
Dec 14, 2005 09:09 AM
B2FiNiTY
Mar 8, 2005 07:40 PM
deeksmooth
Jan 10, 2004 10:43 AM
White Dragon
Aug 4, 2003 03:46 PM
