Differential Bearing
Old May 24, 2003 | 03:44 PM
egciviccx's Avatar
Default Differential Bearing
I did a search and didn't come up with anything, what are symptoms of a bad differential or diff. bearing? I think mine is going bad, sometimes when the car is in gear it hums as rpms go up, and it looks like there is play between the axle and trans. on the passenger side.
Old May 25, 2003 | 05:20 AM
egciviccx's Avatar
Default Re: Differential Bearing (egciviccx)
Old May 25, 2003 | 07:26 AM
TREVER's Avatar
If any trans bearings are going bad they generally moan as speed increases. What oil is in your trans?
Old May 25, 2003 | 07:39 AM
egciviccx's Avatar
Default Re: Differential Bearing (TREVER)
honda MTF
Old May 25, 2003 | 02:10 PM
egciviccx's Avatar
Should I start looking for a new trans.
Old May 25, 2003 | 02:25 PM
K20  EG's Avatar
I would pull it apart and inspect everything ...and get to the bottom of that noise
a Diff bearing failure could seriously damage your trans beyond rebuilding
keep us posted on what your going to do
but if its making noise now ...i wouldnt race on it ...
just my .02$
Old Mar 6, 2004 | 02:38 PM
teg92's Avatar
Default Re: Differential Bearing (K20 EG)
I'm reassembling a tranny right now, and when the new OEM LSD diff is in place and spun as fast as I can spin it by hand, the bearings make a noise as if they are not lubricated well enough. The bearing itself feels tight.
I tried putting in my original open diff and spinning it to compare, and its roughly the same, a little quieter.
Is this normal or should there be nearly NO sound when you spin a diff in the casing?
corpsebesideme
Transmission & Drivetrain
Jul 19, 2017 07:38 PM
soupE__
Dec 2, 2010 08:30 PM
Rooftop voter
Nov 3, 2010 06:11 PM
Hal9000
17
Jan 12, 2009 08:27 PM
cb hatch
Jul 1, 2008 11:09 AM
