differential
Old Jul 9, 2003 | 11:28 AM
durrett syndrome's Avatar
Default differential
i broke the differential in my transmission and i was wondering what the chances of my casing being cracked please post if you know the price for casing also
Old Jul 9, 2003 | 11:54 AM
torr's Avatar
Default Re: differential (durrett syndrome)
i broke my diff once. the gears broke into about 10 pieces and shot through the tranny. fluid leaked everywhere. the clutch housing costs about 350-400 from the dealership. i don't know how much the tranny housing would be. the only way to check if your tranny case is still good is to thoroughly clean and inspect it for cracks. see if the case will hold water. don't be mistaken by cast molding lines, they look like cracks but are just the way they were molded.
Old Jul 9, 2003 | 01:01 PM
if this piece on my tranny is broke..... my uncle has an aluminum welder. does it have to be perfect?? also my trany is not leaking or anything.
Old Jul 9, 2003 | 02:47 PM
torr's Avatar
Default Re: (durrett syndrome)
if your diff. is broke i would not recommend welding it. i would buy one from the junkyard or just try to find another one. aftermarket ones are great,but you'll be paying alot more.
Old Jul 9, 2003 | 02:58 PM
i was talking about the casing. but i am going to get an aftermarket differential though. is phantom grip recommended to you? quaife is too much for me rite now
Old Jul 9, 2003 | 03:42 PM
AzG35's Avatar
The internals could have pieces broken inside them. When I broke my diff, it cracked the bottom of my housing and also some of the fins inside. Wasn't a pretty site. Now would be the optimum time for a real LSD (quaife, Kazz, ITR/CTR). Also, make sure that you clean out all the parts, there will be metal shavings everywhere inside, and you don't want those to go through your synchros and bearings. Trust me, I had my tranny apart 5 times til it was right.
Old Jul 9, 2003 | 04:53 PM
torr's Avatar
Default Re: (AzSi22)
i have a quaife right now, i paid 810 for it. getting the right diff. depends on how far you want to take it. itr diffs. are good, phantom grip wouldn't be worth it, my friend broke a kaaz pushin 250 hp. quaife- probably the best you can get. they even warranty drag racing.
Old Jul 9, 2003 | 04:58 PM
Rocket's Avatar
Default Re: (torr)
Quaife is bad ***. I've installed like 12 of them and no signs of any stress on them.
They are about as strong as any part can get. Made in the same area in England where alot of F1 stuff is made.
Old Jul 9, 2003 | 08:24 PM
thanks everyone for you imput... but how come phantom grip is not recommended???
Old Jul 10, 2003 | 05:44 AM
torr's Avatar
just simply do a search on them. you'll find out that more people don't like them
Old Jul 10, 2003 | 07:52 AM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durrett syndrome &raquo;</TD></TR><TR><TD CLASS="quote">thanks everyone for you imput... but how come phantom grip is not recommended???</TD></TR></TABLE>
The Phantom Grip is only as strong as the diff. So, if you already broke a stock one, chances are you'll break another one.
BattleEK
14
Sep 17, 2018 09:25 PM
bbLUDE
Mar 17, 2008 11:38 AM
xlusiveracer
15
Feb 14, 2007 11:10 AM
GirlTechImports
Mar 20, 2002 07:14 AM
Lei Siew Long
Sep 17, 2001 01:50 PM
