Difference in water pumps (B16A2 vs. B18C1)
Old Nov 1, 2002 | 11:39 AM
Boost2NA's Avatar
Default Difference in water pumps (B16A2 vs. B18C1)
Just like topic says. Reason i ask is I have Ls-Vtec and im running a Gsr belt with a b16 water pump. We cant get the timing belt to tighten up all the way. We think that the gsr pump may be a little different from the B16 pump. Thanks any info will be helpul.
Old Nov 1, 2002 | 11:50 AM
10K2HVN's Avatar
Default Re: Difference in water pumps (Boosted99Si)
all the "vtec" water pumps are the same..
it should say "22T" on the sproket...
the angle of the blades on the turbine should at a 45 degree angle from center..
Old Nov 1, 2002 | 02:28 PM
Boost2NA's Avatar
Default Re: Difference in water pumps (10K2HVN)
ok we might have a problem......my pump has 18t stamped on it. What pump do I have. Im guessing a 18t is not a vtec pump. Please respond ASAP
Old Nov 1, 2002 | 03:10 PM
skunked's Avatar
18t is from a non VTEC block....
Old Nov 1, 2002 | 08:00 PM
10K2HVN's Avatar
Default Re: Difference in water pumps (skunked)
thats funny, i thought non-vtec water pumps had 19Teeth...?
does yours even say "HONDA" or "YAMADA" on it?!? cause mine says both!
did it come in a pink bag???
go get a real vtec water pump..!
Old Nov 1, 2002 | 09:13 PM
Boost2NA's Avatar
this is the strangest thing......I personally took that water pump off my b16 block and put it on my ls-vtec motor. My old bottom end had never been tampered with (that i know of). So i have no clue on how i ended up with a non-vtec pump. kinda spooky being its the day after halloween . Im glad the shop caught this little mix up cause im sure on the dyno with a GSR belt and LS pump plus 18 psi, things could of got nasty . Well thanks for all the info guys, my car will be finished early next week. Ill be sure to post my dyno plot.
B00sted Eg2
May 7, 2009 01:34 PM
Egpower88
Feb 6, 2009 06:30 PM
SpoolnG2
Mar 21, 2005 03:05 PM
built562
May 4, 2003 07:27 PM
getgot2
Dec 22, 2002 12:54 PM
