The difference in compression between B20B VS B20Z
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">Just to add there were some CRV - 97-98 spec motors (came with 5spd 4WD) tranny which were rated at 145ps, they had 9.2 c/r
http://www.honda.co.jp/HOT/ModelData.../shogen97.html
great info.
is this the motor that came with the P8R head?
i hope so, I dont want 126 crank HP, that sucks
great info.
Originally Posted by Nova_Dust
Currently, I am going through a deal. It is a JDM B20B engine that came from Orthia, 98 Spec, 9.2 CR with P75 head. I saw the engine last night and the owner took me for a spin around the neighbourhood.
It has the lower type IM. The last compression numbers he had were 170/175/175/175 on a cold engine. He is going to do another one for me when the time comes to buy it.
That engine is mated with JDM ITR 4.785 tranny with Kaaz LSD. He let me drove the car but I was afriad to step on it. But damn, that LSD is tight (with PS belt off). I like the pull, it felt nice. He shifted at 3000RPM range and basically, all the shifting was done in less than 5 seconds, from 1st to 5th.
Runs on same 87 octane gas, has more power and torque than my Y7, great price and from a great guy. I will shoot myself for not jumping on this deal.
more info:
orthia 95-99 Spec Motor
http://www.honda.co.jp/HOT/Mod....html
総排気量(cm3)
1,972
内径×行程(mm)
84.0×89.0
圧縮比
9.2
最高出力(PS/rpm)*
145/6,200
最大トルク(kg・m/rpm)*
18.2/5,200
96 SMX spec motor
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 8.8
性能 最高出力(PS/rpm)* 130/5,500
最大トルク(kgm/rpm)* 18.7/4,200
99-00 SMX wagon
エンジン型式 B20B
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 9.6
性能 最高出力(PS/rpm)* 140/5,500
最大トルク(kgm/rpm)* 19.0/4,200
another variation of B20 is Stepwagon
エンジン型式 B20B
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 9.2
能 最高出力(PS/rpm)* 125/5,500
最大トルク(kgm/rpm)* 18.5/4,200
99-00 Spec B20 Stepwagon
エンジン型式 B20B
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 9.6
能 最高出力(kW[PS]/rpm)* 99[135]/5,500
最大トルク(N・m[kg・m]/rpm)* 184[18.8]/4,200
last variant of B20 is from CRV:
96 spec
エンジン型式 B20B
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 9.6
97-98 spec (came in 2 flavours)
エンジン型式 B20B
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 8.8 9.2
性能 最高出力(PS/rpm)* 130/5,500 145/6,200
最大トルク(kgm/rpm)* 18.8/4,200 18.2/5,200
99-00 Spec
エンジン型式 B20B
総排気量(cm3) 1,972
内径×行程(mm) 84.0×89.0
圧縮比 9.6
性能 最高出力(PS/rpm)* 150/6,300
最大トルク(kgm/rpm)* 18.8/4,500
hope this helps
few of my B20s I had:
in my old EG
B20 in my ITR (now Nova Dusts motor)
sorry i know this thread is a bit old but i'm looking at getting a b20b right now... and of course i want the hi compression... can anyone confirm if the knock sensor is an indicator of this? as some have knock sensors... and some don't...
this link shows that the b20z has a knock sensor and a b20b doesn't (USDM) but from what i am finding out jdm b20b's seem to have knock sensors as well... on both short and long neck IMs...
http://hybrid2.honda-perf.org/....html
thanks!
thanks!
I am thinking about buying a B20 from hmotors, did everything come out okay? are they legit? I sent them an email and told them i was looking for the higher compression motor and even told them about the knock sensor cause i have talked to afew other motor swap places and they tried to tell me i did not know what i was talking about which i thought was hillarious and that all jdm B20's were high compression. I think it horrible how people try to rip people off i just wasnt to buy a motor and not get stuck in the rearend at the same time and get what i am looking for.
I went and looked at a B20Z2 longblock today. The fella told me the guy he got it from pulled it out of a wrecked CRV, (rear-end damage only) at a salvage yard that had 50,000 miles on the odometer. He was previously running the motor in a 5th gen Civic hatchback.
The block stamp, (square/flat spot near tranny) was stamped B20Z2 and the back of the block had a threaded hole for what seemed to be the original location of the knock sensor. I'd imagine he had the sensor out of the block because he was running it in an obd1 car with an obd1 ecu. The intake manifold seems to be from an obd1 LS motor.
This motor is very clean and I plan on picking it up for a very good price. I just wanted to double check and make sure it's the high compression 9.6:1 B20Z.
Does it sound like it indeed is what I'm looking for? (High Compression B20)
yes all b20z's are the higher compression motor i have a b20z2 in my da and it was out of a 2000 crv that had 73,000 miles and it runs great i love it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">yes all b20z's are the higher compression motor i have a b20z2 in my da and it was out of a 2000 crv that had 73,000 miles and it runs great i love it.</TD></TR></TABLE>
Awesome...thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">no prob, what trans you bolt'n it 2?</TD></TR></TABLE>
Haha...98 Spec JDM ITR tranny, (lsd & 4.7 final drive)
My face when I finally get to drive it:
Nice i have a jdm b16 trans on mine and i love it, the only thing thats sucks is highway driving at 70mph i am at 4,000rpm but for the the curvy backroads its awesome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">The only thing thats sucks is highway driving at 70mph i am at 4,000rpm but for the the curvy backroads its awesome.</TD></TR></TABLE>
Yeah...Maybe it will help keep me from speeding so dang much on the interstate/freeway.
By the time this setup is in the car and running...I'll have another daily driver so this car will be mainly autox and nice day driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">whats car is the motor going in?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">nice ride man, what mods are you gonna run on the motor?</TD></TR></TABLE>
Thanks. Nothing fancy for now. Just your basic intake/header/exhaust.
One more question. My car is 98 Honda Civic Ex, (obd2a) and I'll be reusing my stock engine harness with this B20Z2 swap. Will either LS P75 ECU's work, (obd2a or obd2b) or do I need to stick with obd2a?
Thanks
Thanks
yes up want to use the integra P75 ecu from a 96-98 RS and LS because the 99-01 units have the vehicle immobilizer device, you can use the 99-01 units but the immobilizer needs to be removed and that will cost more money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">yes up want to use the integra P75 ecu from a 96-98 RS and LS because the 99-01 units have the vehicle immobilizer device, you can use the 99-01 units but the immobilizer needs to be removed and that will cost more money.</TD></TR></TABLE>
Thank you sir.
Thank you sir.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bac91Da »</TD></TR><TR><TD CLASS="quote">do you need any info on what engine mounts you need?
Nah...I already have the timing belt mount bracket and rear T mount bracket.
Thanks so much for your help.
