Difference between USDM & JDM ITR Pistons
Old May 14, 2004 | 01:48 PM
I3ackfire's Avatar
Default Difference between USDM & JDM ITR Pistons
I just want to know the difference between the two, because the JDM yeild a slighty higher compression, why is it?
DO they have a higher dome?
Old May 14, 2004 | 03:11 PM
non-VTEC's Avatar
Default Re: Difference between USDM & JDM ITR Pistons (I3ackfire)
yes the JDM ones have a bigger dome.
Old May 14, 2004 | 03:32 PM
I3ackfire's Avatar
Default Re: Difference between USDM & JDM ITR Pistons (non-VTEC)
Why are they bothed class as P73 then, if they are differnet? How would you beable to tell.
How mnay more degree's bigger are they then the USDM?
Old May 14, 2004 | 03:44 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">Why are they bothed class as P73 then, if they are differnet? How would you beable to tell.
How mnay more degree's bigger are they then the USDM?</TD></TR></TABLE>
well the JDM P73 piston's part number is: P73-00
US P73 is: P73-A0 ("a" I assume = american)
Dunno the actual heighth specs but these images help show the differences.
JDM ITR piston (P73-00)...
US ITR Piston (P73-A0)..
Old May 14, 2004 | 04:12 PM
I3ackfire's Avatar
Default Re: Difference between USDM & JDM ITR Pistons (Katman)
Perfect that is what I was looking for!
So the bigger dome raises compression. How big of a compression difference is there between the 2?
Old May 14, 2004 | 04:17 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">Perfect that is what I was looking for!
So the bigger dome raises compression. How big of a compression difference is there between the 2?</TD></TR></TABLE>
well US ITR engines are rated at 10.6cr, JDM ITR is rated at 11.0cr, so approx. .5 points higher w/an ITR piston.
Old May 14, 2004 | 04:54 PM
I3ackfire's Avatar
Okay, Another question. Is it a good idea to use pistons that were previously used before, or can you buy after market ones, and if so who do you recommend.
I apprecciate all the help Katman
Old May 14, 2004 | 06:29 PM
Sliced Beard's Avatar
used pistons work fine just get a new set of rings and you are good
Old May 15, 2004 | 08:32 AM
rocco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>**** its crazy how that hairline difference in size will make a difference in performance
Old May 15, 2004 | 09:47 AM
mmuller's Avatar
Mad Scientist
Default Re: Difference between USDM & JDM ITR Pistons (rocco)
I ''think'' the difference in between the 2 is 2.32cc's
iheartmyctr
Jul 3, 2008 07:01 AM
gulftiresinc
13
Sep 5, 2004 02:59 PM
94TealGSR
Nov 30, 2002 01:05 AM
phantoman
Nov 21, 2002 12:09 PM
iH8RICERZ
Nov 14, 2002 01:25 AM
