Difference between LS/VTEC and GSR
Old Aug 13, 2003 | 05:08 AM
7rrivera7's Avatar
Default Difference between LS/VTEC and GSR
I was going LS/VTEC but then became aware of the oiling issues and that it cannot rev as high as my B16 (9k). A friend of mine installed a GSR and it's running great!
Can I install my ported B16 VTEC head on a GSR block or do I need a GSR VTEC head?
Can someone give me the pros and cons of LS/VTEC vs GSR?
Thanks!
Old Aug 13, 2003 | 09:32 AM
roadawg's Avatar
Default Re: Difference between LS/VTEC and GSR (7rrivera7)
Search is your friend.
Old Aug 13, 2003 | 10:17 AM
1_bad_EF's Avatar
the heads are interchangeable. ITR's are very similar to b16a heads. So thats why they call a gs-r bottom end w/ b16a head "poor man's R" I THINK ITR intake valves are bigger.
I think the gsr is the way to go. I put a gsr crank in a ls block cuz i built a "REAL poor man's R" I couldn't find a gsr block that didnt need sleeves but they had good cranks. I would say i am most worried about my oiling situation in my ls block. I have good pressure and all is good, but i'm crossing my fingers when I rev it out to 9.2k rpm.
If I could do it over, I would do a gsr block.
my .02
Old Aug 13, 2003 | 01:15 PM
eh2 nihonjin's Avatar
gsr head holds more compression because of the combusion chambers shape
Old Aug 13, 2003 | 06:24 PM
mr.beeks's Avatar
Default Re: Difference between LS/VTEC and GSR (eh2 nihonjin)
do your poormans type R
its more reliable..
Old Aug 13, 2003 | 08:25 PM
david90's Avatar
what is ls/vtec? is that an ls block with a vtec head?
Old Aug 14, 2003 | 07:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">what is ls/vtec? is that an ls block with a vtec head?</TD></TR></TABLE>
correct.
Old Aug 14, 2003 | 09:09 AM
skribblah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">...it cannot rev as high as my B16 (9k)...</TD></TR></TABLE>
what makes you think that an ls/vtec cant rev that high? i know people that have re'd to that daily, with the occasional flash to 10. but naturally they are beating the **** out of the engine, but with the correct componenets, a 8500RPM redline wont even be a problem for performance & reliability.
Old Aug 14, 2003 | 09:12 AM
david90's Avatar
why is it called poorman type r?
Old Aug 14, 2003 | 10:58 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">why is it called poorman type r?</TD></TR></TABLE>
cuz its a mimick of a Type-R engine setup, mainly in regards to the block internals & head being used. Yes, a GSR block does have a 1.8L crank/rods/pistons but its not a Type-R crank/rods/pistons/slightly ported head being used ... "R" parts are balanced & specially treated by Honda unlike non-R parts.
ser13
Apr 15, 2008 07:46 AM
LiL PaKi
28
Apr 29, 2007 02:30 PM
DsBananas94LS
Aug 30, 2004 08:26 PM
B16b2b
Mar 21, 2003 02:07 PM
94si94cx
Jan 24, 2003 06:50 AM
