Difference Between B16A Head & B16B Head
Old Mar 12, 2007 | 11:01 PM
rapinsoul's Avatar
Default Difference Between B16A Head & B16B Head
Hi Guys,
Can anyone tell the difference's between B16A head and B16B head. Need the info ASAP as i am planning for a HYBRID with a B20B Block, as far as i know the compression level on both the heads are different!! what if i use a B16A Head But The Cam and Valve and the Retainers i use the B16B TypeR?? Will it be the same as a B16B head?
Old Mar 13, 2007 | 10:18 AM
B16b-EJ8's Avatar
Default Re: Difference Between B16A Head & B16B Head (rapinsoul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapinsoul &raquo;</TD></TR><TR><TD CLASS="quote">Hi Guys,
Can anyone tell the difference's between B16A head and B16B head. Need the info ASAP as i am planning for a HYBRID with a B20B Block, as far as i know the compression level on both the heads are different!! what if i use a B16A Head But The Cam and Valve and the Retainers i use the B16B TypeR?? Will it be the same as a B16B head?</TD></TR></TABLE>
Here you go my friend all you need to know about the b16b...
http://www.ek9.org/forum/showthread.php?t=1
nicole_
Aug 15, 2014 04:38 AM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
gsr squirrel
Apr 3, 2002 01:37 PM
HaUTSaauce
Jan 10, 2002 02:44 PM
gingboy
Jul 10, 2001 05:27 PM
