Did LS/VTEC conversion and now low compression on all cylinders..
Old May 20, 2007 | 03:59 PM
Slammd Sol's Avatar
Default Did LS/VTEC conversion and now low compression on all cylinders..
Bent the valves on the stock LS head after revving too high at the track, so I swapped on a GSR head with G.E. Vtec conversion kit(head gasket generously coated with copper spray), ARP studs, GSR water pump/timing belt, and ITR oil pump. After a day or 2 the engine started running rough so I did a compression test and got 130-140 psi on all 4 cylinders. I bought the head used so I might have gotten scammed on a shitty GSR head. Any ideas what can cause low compression on all cylinders? Also I found some weird white stuff on the out side of the sleeves where the water flows through.. Not sure what the hell that is.. Any ideas?
Old May 21, 2007 | 04:28 AM
Slammd Sol's Avatar
t t t
Old May 21, 2007 | 06:36 AM
92redhatch's Avatar
i had similar problems with my b16 and they told me that it was time to tear it apart and build it again. Do a leak down and see where your leaking compression. in my case it was my rings.
Old May 24, 2007 | 07:18 PM
Slammd Sol's Avatar
Well, Just got the head back from the machine shop and they said it was perfect. I'm hoping the block isnt bad..
Old May 24, 2007 | 07:44 PM
vtec4max's Avatar
did you get the block resurfaced too, before installation?
Old May 25, 2007 | 02:44 PM
Slammd Sol's Avatar
Default Re: (vtec4max)
Block hasn't been resurfaced.. I really hope it doesn't need to be. I just got the haed back from the machine shop today.. They did a few pressure tests on it which all came back excellent, however they said the head was warped 1/8000th, so I had them deck it. Hopefully this will fix the problem.
Old May 26, 2007 | 08:11 PM
base-op.1320's Avatar
Default Re: (Slammd Sol)
Are you sure that it wasn't slightly off on timing causing valves to open to early and not allowing full compression?
Old May 30, 2007 | 06:05 PM
vtec4max's Avatar
Default Re: (base-op.1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by base-op.1320 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure that it wasn't slightly off on timing causing valves to open to early and not allowing full compression?</TD></TR></TABLE>
point, if you're going to build it right. you must get it check out, Keep in mind that that's not a steel block. it's aluminum, it's just almost as bad as the head when it comes down to warpage.
kmac714
May 23, 2010 02:36 PM
crxowner
Mar 12, 2006 11:21 PM
slthatch
Sep 3, 2005 03:29 PM
MugenGSRb18
Sep 7, 2004 12:43 AM
