did compression test ?? are these readings ok
Old Oct 22, 2004 | 09:28 PM
93FastLs's Avatar
Default did compression test ?? are these readings ok
#1 - 215 #2 - 210 #3 -210 #4 - 210 it's a b18c1 with 150k plugs look ok kinda look grimey looken but the electrodes look aight..
Old Oct 22, 2004 | 09:35 PM
im_poor's Avatar
Default Re: did compression test ?? are these readings ok (93FastLs)
looks good.
Old Oct 22, 2004 | 10:54 PM
bobbygee's Avatar
Default compression test
This test look great. The key is to have them at about the same number.
If one is way below the others then you have a problem.
200 across the boards is great.
Old Oct 22, 2004 | 11:25 PM
93FastLs's Avatar
koo... i just wanted to know if that was safe
Old Oct 22, 2004 | 11:54 PM
localmotion's Avatar
Compression readings only tell you the condition of the compression rings, you could have bad oil control rings and compression be good.
Old Oct 23, 2004 | 01:14 AM
Mike K's Avatar
Default Re: did compression test ?? are these readings ok (localmotion)
in addition to the compression test, do a leadown test for a more accurate reading of your engine's condition.
so far, the compression test numbers are excellent. go from there.
Old Oct 23, 2004 | 08:24 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: did compression test ?? are these readings ok (Mike K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_poor &raquo;</TD></TR><TR><TD CLASS="quote">looks good.</TD></TR></TABLE>
Old Oct 25, 2004 | 04:59 PM
A leak down test won't tell you the condition of the oil control rings.
Old Oct 25, 2004 | 05:45 PM
93lsd's Avatar
i would also do a leak down test, because with that you can pinpoint where the most wear is...
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
Got_soy
28
Aug 8, 2005 12:49 PM
Azcheron
Jun 23, 2005 09:34 PM
gsr~hatch
Apr 17, 2003 03:19 PM
