detonation solutions? HELP!
Old Feb 12, 2003 | 08:16 PM
  #26
Fatty_1775's Avatar
Default Re: detonation solutions? HELP! (Tommyyy)
If your talking to me, not yet.
Old Feb 12, 2003 | 08:27 PM
  #27
Halo's Avatar
Default Re: detonation solutions? HELP! (gsrteg)
have you looked into getting a thicker headgasket? i.e-cometic
Old Feb 12, 2003 | 09:08 PM
  #28
Dr_EluSivE's Avatar
Default Re: detonation solutions? HELP! (Halo)
sounds like you are running lean. Genrally if its pinging its detonating before the plug fires.. SO plugs probably arent gonna do it. I would bump your FP, and if that doesnt work try bigger injectors. A A/F guage is really handy for this, see if someone will let you borrow one or get one yourself. Pinging WILL kill your motor if you dont stop it.
Dr.
Old Feb 13, 2003 | 07:49 AM
  #29
Tommyyy's Avatar
Default Re: detonation solutions? HELP! (Dr_EluSivE)
who are you talking to dr. elusive, ive got all of the above...
to the first poster of this thread, did you check and make sure that your rotor in your dist. wasnt loose or misaligned ? Alot of the times its the stupid little stuff that you over look...
Old Feb 13, 2003 | 11:48 AM
  #30
rotten's Avatar
I'd suggest a couple things.
1) Use higher octane fuel. Mix race gas with 93 octane, or use toulene to boost your octane level.
2) Get like a Hondata to tweak your fuel map, and you'll need a A/F gauge.
Old Feb 13, 2003 | 12:15 PM
  #31
Tommyyy's Avatar
Default Re: detonation solutions? HELP! (rotten)
agreed, just fill her up with 94 and get a hondata, for sure...
then boost the ever loving **** out of her
and get bigger injectors, for sure, and an FPR w/gauge...
[Modified by Tommyyy, 9:16 PM 2/13/2003]
[Modified by Tommyyy, 9:17 PM 2/13/2003]
Old Feb 13, 2003 | 12:16 PM
  #32
Blaze45's Avatar
Brrraaaap!
A/F gauges are not the accurate so just buy some 310cc injectors and a super AFC or a SMC so you can tune for more power and less pre ig.
Good Luck!
Blaze
Old Feb 16, 2003 | 01:11 PM
  #33
Tommyyy's Avatar
Default Re: detonation solutions? HELP! (Blaze45)
I fixed my detonation this weekend, with the help of my buddy...
Here are the steps we went through to fix her up, maybee this could be helpfull to you...
1: Loose distributor rotor screw. Yup. Mista Bone gets a cookie. Replace rotor, add new screw WITHOUT stripped threads.
2: Timing belt had 20 mm play on the long side, 10 mm play on the W/P side. POSSIBLY more if I would have played with it, but the crank turned at LEAST 4-5 degrees without moving the cam. Replace and tighten.
3: Engine Ground straps? Where? Add 2.
4: Fuel MAP? Back to baseline plus 2% fuel on boost.
5: Distributor bolts... All 3 loose, turn the dizzy by hand. Every time he hammered it, the dizzy advanced to full advance, every time he lifted, it shot back to full retard. Tighten, and set it.
6: Fuel pressure was WAY too high for the 440's and the rich MAP. Reset it to 38 psi and calibrate MAP accordingly.
7: Plugs were too hot. 1 step colder.
She picked up 2 psi of boost. Peaks at 9.5 psi now instead of the usual 7.5. I'm assuming the timing belt being THAT loose was retarding the cam so far the overlap was blowing the boost out the exhaust side.
Old Feb 16, 2003 | 07:28 PM
  #34
gsrteg's Avatar
Ok guys, since the last time Ive posted, Ive added ITR cams. Since I have added these cams it has spark knocked worse than with the B16 cams. Since it has been raining the past couple of days it has pretty much been fine with hardly any spark knocking, but I know as soon as the weather warms up it will be back to the way it was.
What size injectors will be good for my setup? Anyways, the VTEC sounds mad with the ITR cams!!
Mydogisgone
Sep 3, 2007 06:24 PM
Quitripin
16
Aug 18, 2004 09:20 PM
Steemo
10
Jul 30, 2004 08:40 AM
T_Rex
Feb 15, 2003 07:56 PM
HX_Guy
Jan 21, 2002 09:27 AM
