delete
Old Dec 20, 2009 | 05:06 PM
jdmtom's Avatar
Default delete
i cant post this int he engine topic cuz it it wont let me
but i just got a 1996 honda civic coupe hx with a d16y8 swap with a y7 manifold running a p2e ecu.
keeps bogging for some reason only under 3 grand rpms
and over 3grand rpms it nida jerks once and a while.
wtf is going on!!
any helps or info would be great!!
i got new spark plugs and wires too btw thanks
Old Dec 21, 2009 | 09:53 AM
delsolproblems's Avatar
Default Re: ek bogging out need help!
Without any history of the car or the problem or even a CEL, you'll need to just go down the line, checking each of the most likely systems until you find what's wrong. Check the grounds, timing, filters, sparks, TPS voltages, MAP sensor voltages and the fuel pressure, probably in that order.
Old Dec 21, 2009 | 05:19 PM
jdmtom's Avatar
just traded the car as-s but thanks..
i found more info about the car..
heater hose... haha
SlammedHx
19
Jun 26, 2012 08:07 PM
jdm_xsi206
Jun 22, 2010 07:55 PM
yahright
Mar 22, 2009 10:44 AM
civic-4-ges
Aug 23, 2004 12:12 AM
91civicmoneypit
Dec 12, 2003 12:01 PM
