Degreeing Cams?
Old Feb 15, 2006 | 08:49 PM
EnzoSpeed's Avatar
Default Degreeing Cams?
What exactly does degreeing cams do? Does it find the optimal cam gear settings instead of using trial and error on the dyno?
I ask because my new cam came with directions on how to degree it, even though it's for a SOHC. I thought cam degreeing was DOHC stuff.
Old Feb 16, 2006 | 02:38 AM
NJIN BUILDR's Avatar
Default Re: Degreeing Cams? (EnzoSpeed)
Degreeing the cam locates it in proper relationship with the crank.This eliminates variations due to milling the head or block,timing belt length,gear variations etc...
Glenn
Old Feb 16, 2006 | 02:50 AM
EnzoSpeed's Avatar
Default Re: Degreeing Cams? (NJIN BUILDR)
So is this some kind of necessary step? I know my block was never decked, and I'm 90% sure my head was never milled. The timing belt is new so it shouldn't be stretched. Everything should be in spec.
Doesn't degreeing require an adjustable cam gear?
Old Feb 16, 2006 | 03:07 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">So is this some kind of necessary step? I know my block was never decked, and I'm 90% sure my head was never milled. The timing belt is new so it shouldn't be stretched. Everything should be in spec.
Doesn't degreeing require an adjustable cam gear?</TD></TR></TABLE>
Most people don't do it... but it is recommended.
Old Feb 17, 2006 | 12:13 AM
EnzoSpeed's Avatar
Default Re: Degreeing Cams? (JDM_Ej)
Bump for more info on this "degreeing" business. Is it essentially just finding the optimal cam gear setting? Can you degree a cam without an adjustable cam gear?
Old Feb 17, 2006 | 03:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote"> Can you degree a cam without an adjustable cam gear?</TD></TR></TABLE>
You can check it,you just can't change it.
Glenn
Old Feb 17, 2006 | 05:30 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Is it essentially just finding the optimal cam gear setting?</TD></TR></TABLE>
Not optimal...just where the cam manufacturer intended for specific valve events to happen in relation to the crank.
Old Feb 17, 2006 | 02:37 PM
EnzoSpeed's Avatar
Default Re: Degreeing Cams? (EE_Chris)
Thanks guys
MatakiRotorD16
Jul 24, 2011 07:43 PM
black99x
Apr 11, 2008 12:13 PM
00-501itrspec
Dec 2, 2007 11:33 AM
mtwnfabrication
Aug 10, 2005 12:03 AM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
