datalogging not working?
Old Jul 3, 2006 | 06:51 PM
TehMan's Avatar
Default datalogging not working?
i'm using a p06 ecu
ok we have the pins in the ecu...and plugged the xenocron datalogging cable into it and into the laptop...we cut j12...we've tried to run freelog and uberdata....we thing on the cable flickers a green light but we're not getting any response from the laptop...what could be the problem?
Old Jul 3, 2006 | 07:02 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: datalogging not working? (TehMan)
Could be anything man. I'm trying to do the same thing using ECU Control and Crome.
Did you install the datalogging plugin on your ROM?
The support for DIY ECU modifications SUCKS... trial and error unfortunatly.
Old Jul 3, 2006 | 07:09 PM
TehMan's Avatar
Default Re: datalogging not working? (JDM_Ej)
i hooked the cable into the laptop and it said new hardware and we installed it onto the laptop...
am i suppose to just cut one side of j12 or remove it completely?
Old Jul 3, 2006 | 08:17 PM
TehMan's Avatar
well it datalogs on uberdata for just a second and then it stops...and it will log and then it won't...i dunno whats wrong with it...i checked the solder connections and they are nice and strong...
Old Jul 4, 2006 | 05:02 PM
TehMan's Avatar
so i'm guessing noone on this site knows how to do this?
Old Jul 4, 2006 | 11:25 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
No one ever answers in here. I would PM Kenji if you want some help.
Old Jul 5, 2006 | 01:16 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMan &raquo;</TD></TR><TR><TD CLASS="quote">well it datalogs on uberdata for just a second and then it stops...and it will log and then it won't...i dunno whats wrong with it...i checked the solder connections and they are nice and strong...</TD></TR></TABLE>
Uberdata requires j12, I do not recommend ubderdata.
1. Make sure quick datalog + rtp is installed onto the eprom/ecu you are trying to log with.
2. Make sure j12 is removed
3. Make sure your datalogging cable is pined out properly
4. Make sure your port settings in crome/laptop/serial cable are setup properly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">No one ever answers in here. I would PM Kenji if you want some help. </TD></TR></TABLE>
Good luck with that
Old Jul 5, 2006 | 03:47 AM
ylfotevoli's Avatar
Default Re: datalogging not working? (mtber)
http://www.hondata.com
EG6 Love
Engine Management and Tuning
16
Oct 9, 2011 09:13 AM
DelsolioGSR1996
Sep 5, 2006 08:50 AM
JDMlyfestyle
37
Oct 16, 2005 08:42 AM
ramennoodles
Apr 3, 2005 08:04 PM
buckfittyone
Dec 12, 2004 10:16 PM
