Coolant line question...
Old Jul 4, 2006 | 07:54 PM
slowteg550's Avatar
Default Coolant line question...
The setup is a b18c1 head, b18a1 block... 2.0 liter FI build, 550+ whp goal. I'm not running a heater core, I am running the lines to my TB...
The water tube I have for the back of my block only has the one small port on it, no 5/8" ports, so now I have no where to run the line from the 5/8" port on the side of the head (the port is on the passenger side of the head, about in the middle between the feed/return main ports)
So my question is, can I cap this off? To my knowledge it was only to supply the heater core with coolant, that then dumped back into the water tube on the back of the block. With me not using my heater core now, and not having a port on my new water tube, can I just unscrew the port out of the head and put a bolt in there?
Old Jul 4, 2006 | 07:57 PM
IN VTEC's Avatar
Default Re: Coolant line question... (slowteg550)
You can buy a LS or B16 thermostat housing.
Old Jul 4, 2006 | 07:59 PM
slowteg550's Avatar
Default Re: Coolant line question... (IN VTEC)
U mean water neck? Or does the ls therm housing have an extra port in it?
Old Jul 4, 2006 | 08:05 PM
IN VTEC's Avatar
The non-GSR thermostat housings have an extra port for the heater core since it isn't on the water pipe.
Old Jul 5, 2006 | 03:46 AM
slowteg550's Avatar
so why can't you just plug off the head?
Old Jul 5, 2006 | 07:39 AM
IN VTEC's Avatar
You can. Nothing wrong with that.
EF9_TryMe
May 18, 2012 11:20 AM
00EKLSVtec
Dec 22, 2008 07:47 PM
B18 CYA
Aug 29, 2006 06:48 AM
sinneD
Jan 12, 2005 11:02 AM
notstock93
Jan 22, 2004 08:01 PM
