Dart block question
Old Sep 18, 2004 | 11:09 PM
Pandahatch's Avatar
Default Dart block question
Since my other setup gave up the ghost (B20VTEC, not due to sleeves cracking though, but machine shop neglegence on machining the valve seats and them cracking and breaking off in my engine while driving) I figured if I do it again, I'm going all out. I want to do a Dart block since I'll be running around 13:1 CR. Yes high, I have everything else planned already. What headgaskets are best for this, Cometic? Also do the main caps need to be line honed or are they all on spec. I know the cylinders need to be bored to spec for your pistons. I plan on using ACL bearings for this. Thanks in advance.
Old Sep 29, 2004 | 05:49 AM
Moxie's Avatar
Default Re: Dart block question (PandaHatch)
The Cometic gaskets seem to be the #1 choice for most of our customers. Fel-Pro has a new MLS gasket out that looks good, though we haven't yet tried it. The mains are already line honed. As a standard procedure, you should still check all tolerances when you install your bearings. The cylinders need a finish hone. We leave them -.5mm for this.
If you have more questions, email me, or darttech@dartheads.com.
Thanks,
Greg
Old Sep 29, 2004 | 02:47 PM
Pandahatch's Avatar
Thanks for the reply, just wanted to make sure, I knew you had to bore/hone the walls, just didn't know about the mains.
Icon_Ed6
11
Jul 10, 2011 05:05 AM
1337 Si
Sep 3, 2007 08:08 AM
7rrivera7
Jun 23, 2006 12:14 PM
93c1sol
Mar 6, 2006 01:15 PM
VWkila
Feb 22, 2003 10:47 PM
