Damn it got a automatic motor to boost,help...
Old Dec 26, 2005 | 01:50 PM
Samuels's Avatar
Default Damn it got a automatic motor to boost,help...
I went today to get a JDM LS motor. I wanted a 5speed but forgot to tell them that. I had told them that last week but they probably forgot or I talked to someone different then who I got it from today,honestly I just got in a hurry and had a brainfart. I took the motor to my mechanic who in return calls me tonight and says hey did you know this was a automatic motor. The motor also had a broken TPS and the harnesses were chopped to death. This is a well respected shop on hondatech so i'm gonna call them tommorow probably won't help though because that stuff 9 out of 10 times is'nt covered..
How bad is the JDM automatic cams gonna hurt my setup??
I'm running a t3-t4 60 trim 56intake 60exhaust with a full 3inch DP and exhaust. Its a stock JDM LS motor and will be running 8-9psi..
I have extra 5 speed cams should I have them put in??
Should I install my JG cam gears or are they useless??
Somebody help me...
Old Dec 26, 2005 | 03:26 PM
Shawn C's Avatar
In The Garage
not sure about LS stuff, but the jdm auto b16 cams are the cams of choice for turbo b series vtec setups. most people think that the auto b16 cams are junk, but they are almost identical to gs-r cams on the vtec lobe as far as lift goes, but they just have less overlap.
high lift with short duration and minimal overlap = good for turbo
Old Dec 26, 2005 | 04:40 PM
Samuels's Avatar
Default Re: (ShadyEH2)
Anybody have any concrete specs on this I need to let my mechanic know tommorow after work if he is to install my 5 spd cams if so I gotta take them down to him...
Old Dec 26, 2005 | 07:04 PM
Shawn C's Avatar
In The Garage
just find & compare the specs???
hafaadaiteg
May 1, 2008 11:25 AM
Samuels
45
Dec 26, 2005 08:09 PM
BerT-hybrid
Jun 6, 2004 11:51 AM
