DAMN ABS LIGHT.
I have been tryin to diagnosis a problem with my abs light it has been on for the past few weeks and stays on consistently. My pads were low, so I thought changing them would do something, NO. I checked my brake fluid levels, they were perfect, my rotors are fine, and there is a firm stiff pedal, but the damn light WILL NOT GO OUT. Usually when there is a fluid problem both the parking brake light and abs light will stay on, right? If anyone has any suggestions on why my ABS light is on and how to get it off, it would be greatly appreciated.
Oh, and ABS is Working, I checked that as well.
Install a jumper wire in the service check connector and record the flash code from the abs light. The connector is under the gove box and is a two pin connector. Once you get a diagnostic trouble code, you will know what part of the abs system to inspect. email me if you have any question-jfastman@yahoo.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackout95teg »</TD></TR><TR><TD CLASS="quote">What all type of issue's can occur? I am going to do the flash test to get the code but for now Im just trying to get an idea of what might be the problem?</TD></TR></TABLE>
It's really hard to diagnose your problem until you get your code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackout95teg »</TD></TR><TR><TD CLASS="quote"> Oh, and ABS is Working, I checked that as well.</TD></TR></TABLE>
If the ABS light is on, the ABS is disengaged. (maybe your rotors are so warped it feels like ABS
) And it will have nothing to do with the condition of your brakes. Pull the ABS code and find out why it is on. Prob a wheel speed sensor, any 4-X code.
newhondaowner29
Jan 11, 2006 08:11 PM
