ALB light
Old Jul 11, 2004 | 12:26 AM
unKnown's Avatar
Default ALB light
i have a cdn 91 integra gs, i think in the states its not "alb" its "abs" light
but anyways,
the light suddenly turned on today and the brakes were going crazy
felt like major brake fade and the abs was going off like mad
what could be the problem?
happen tonight when i was driving home, goina check the fluids tommorow morning when i wake up
Old Jul 11, 2004 | 09:43 AM
slo2kgsr's Avatar
Default Re: ALB light (unKnown)
Fluid, ABS actuator failing, sensors failing alot of possiblities if you can't figure it out disconnect the ABS actuator and run it in fail safe. You'll have brakes just no ABS
Old Jul 12, 2004 | 04:31 AM
JimBlake's Avatar
Can you pull error codes from a '91?? On my '95 you jumper the same connector as reading ECU error codes. The ABS light flashes its own code instead of (along with?) the check-engine light.
redINTEGRAdriver
Jan 31, 2005 12:01 PM
f22suzuka
Apr 21, 2004 10:15 AM
CNSK
Apr 12, 2003 11:13 PM
oioioi
Oct 11, 2002 02:47 PM
redteg1
Aug 18, 2001 02:42 PM
