D16z6 piston compression
Old Sep 25, 2003 | 08:43 AM
OoHiTzToMMy's Avatar
Default D16z6 piston compression
im about to go turbo on my z6 and was just wonerding what is the stock compression on the z6 and when i upgrade later to better piston what are some set up you guys have
Old Sep 25, 2003 | 11:18 AM
RyanEJ8's Avatar
Default Re: D16z6 piston compression (OoHiTzToMMy)
The stock Z6 has 9.2:1 C/R. I have a Y8 which has a stock C/R of 9.6:1. I am currently using SRP 10.5:1 pistons with Eagle Rods. The reason for high compression now is I only run nitrous and wanted some decent daily driving all-motor power. When I go with boost I will use a 2 mm headgasket to drop the C/R back down into the 9.x:1 range.
Old Sep 25, 2003 | 07:45 PM
Default Re: D16z6 piston compression (RyanCivic2000)
how much power are u planning on making when you boost? ill be happy with 180whp but im shotting for 200 and later on 210 with hondata
Old Sep 26, 2003 | 07:41 AM
RyanEJ8's Avatar
I'm looking for about 300WHP with boost.
Old Sep 26, 2003 | 09:50 AM
is that with stock internalS? becuase thats what im gonna run for now untill i can afford it later down on the road
Old Sep 26, 2003 | 03:22 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoHiTzToMMy &raquo;</TD></TR><TR><TD CLASS="quote">is that with stock internalS? becuase thats what im gonna run for now untill i can afford it later down on the road</TD></TR></TABLE>
No. The shortblock was built with SRP Pistons and Eagle Rods. Check the link in my signature for more info on my build up.
ej1noob
May 24, 2011 01:33 PM
spens 91 Ef
21
Feb 26, 2009 06:37 PM
blkcoupe94
23
Jun 22, 2005 07:58 PM
jdmCivic925
34
Nov 14, 2003 09:26 PM
GOLDBERG
Apr 27, 2003 12:22 AM
