D16Z6 Oil pan, repair or replace?!?
Old Aug 14, 2002 | 12:21 PM
Chris83179's Avatar
Default D16Z6 Oil pan, repair or replace?!?
My oil pan is all smashed up, except in the middle, i am curious if the pan is smashed against the oil pickup. Should I pull the pan and hammer it back out? or just replace it?
I am getting oil pressure so it can't be too messed up.
Old Aug 14, 2002 | 12:57 PM
Turbo Powa's Avatar
Default Re: D16Z6 Oil pan, repair or replace?!? (Chris83179)
I wouldnt recommend you hammering the oil pan. If I were you I'd get a new pan just incase.
Old Aug 15, 2002 | 12:51 AM
D16Z6racing's Avatar
Default Re: D16Z6 Oil pan, repair or replace?!? (Civic LX 29)
Get a new one. You'll warp your old pan so bad that it'll leak. Chage the gasket too. And use Honda-lock sealent.
Old Aug 15, 2002 | 04:01 AM
Mista Bone's Avatar
D Tranny Guru
go find a DX or CX oil pan off a motor that is being thrown away. The pans are the same.
Old Aug 16, 2002 | 11:11 AM
93CivicSI's Avatar
Get a new pan - < 130.00 - Item #13 from Majestic Honda http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
Old Aug 16, 2002 | 10:55 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: D16Z6 Oil pan, repair or replace?!? (93CivicSI)
pan from a CX motor that threw a rod....FREE
Old Aug 19, 2002 | 12:20 AM
Default Re: D16Z6 Oil pan, repair or replace?!? (Mista Bone)
Can't beat that price!
Old Aug 19, 2002 | 06:12 AM
No-Gi's Avatar
Default Re: D16Z6 Oil pan, repair or replace?!? (B18CX-EH)
are all these pans the same? I need a pan for my girls d16y8 and I found a **** load of y7 really cheap. Are they interchangeable? and if you have any FS PM me
drlagares
Engine Machining & Assembly
Apr 15, 2016 09:41 AM
gsrswapdcivic
May 9, 2004 06:50 AM
civickiller
May 17, 2003 08:35 AM
