question for oil pan baffling
Old May 1, 2004 | 08:12 PM
gsrswapdcivic's Avatar
Default question for oil pan baffling
I baffled my own oil pan. has any one else done this? if so did you warp your pan?
I have a oil pan leak and it kinda looks like I may have done this.
new oil pan or no what you guys think
Old May 1, 2004 | 08:18 PM
onePOINTsix's Avatar
Default Re: question for oil pan baffling (gsrswapdcivic)
you probally blew a hole thru it when you welded it, too much heat. Turn down the amps and wire speed (if it's a wig welder) and you'll be fine if go slow. If you didnt weld it then take it back to the place that did and ask them to fix it
Old May 6, 2004 | 02:17 PM
Default Re: question for oil pan baffling (Sideout)
no holes just thought the pan may have warped a little. enough to leak a drip every minute or so it may just be the oil pan gasket too
Old May 9, 2004 | 06:50 AM
pan was warped if you put a baffle in your own pan dont just run a bead douwn it 3 tacks will hold it fine
josh0407
Aug 24, 2007 04:30 PM
TSX TEX
Feb 21, 2007 07:44 PM
civickiller
May 17, 2003 08:35 AM
