d16z6 build up!! need a bit of advice?
Old Feb 5, 2004 | 09:22 AM
integracivic94's Avatar
Default d16z6 build up!! need a bit of advice?
will be building up my d16z6 soon! its getting all new bearings, and stem seals, all gaskets etc.
1, should i coat things like main bearings and con rod bearings in some sort of oil before i install them?
2, Is there any procedure when replacing valve stem seals! or should i just rip em out???
3, Is there any other alternatives to using honda bond???
any suggestions for the rest of build up??? Thanks in advance for any help
Old Feb 5, 2004 | 12:59 PM
Default Re: d16z6 build up!! need a bit of advice? (integracivic94)
bump
Old Feb 5, 2004 | 01:13 PM
JaeOne3345's Avatar
1. refer to your manual, it will tell you. shouldnt be doing a rebuild without it anyway.
2. refer to your manual, it will tell you. shouldnt be doing a rebuild without it anyway.
3. https://honda-tech.com/zerothread?id=717838 (got that using the search)
Old Feb 6, 2004 | 02:22 PM
Default Re: d16z6 build up!! need a bit of advice? (JaeOne3345)
Dont you just love a smart ****!
Old Feb 6, 2004 | 06:08 PM
phatrick2332's Avatar
1.assembly lube
2.follow the manual..its not hard.
3.you can use any gasket sealer you would like.
Old Feb 6, 2004 | 07:07 PM
zensoku207's Avatar
biggest part about building a d16 up is replacing the stock connecting rods with aftermarket ones like ARP.....if you're getting aftermarket rods you won't have to worry about it anyways......
Old Feb 7, 2004 | 11:24 AM
Default Re: (zensoku207)
thanks for the input! plan on using some eagle rods think i have to notch the block for them to fit and some sort of aftermarket pistons have'nt decided on which brand im going with?
Emanuel Olteanu
Sep 21, 2015 06:23 PM
joppe
Mar 20, 2011 12:28 AM
jgomega16
11
Oct 15, 2004 12:19 PM
true
Feb 24, 2003 07:31 PM
