D16y8-low oil pressure?
I usually run around 75 psi at around 4K rpm
last month this dropped down to 60-65
Usually this is a sign of rod bearings in the y8 (past experience)
However I replaced the rod bearings, and still am getting this low reading, directly afterwards
Could this be a sign of even bigger problems?
Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">You getting 50psi at 3k?
What's your idle PSI?</TD></TR></TABLE>
Around 25....which is not low
I guess I am used to higher pressures...and not I may be getting "normal" pressure
Re: (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave »</TD></TR><TR><TD CLASS="quote">have you changed the oil lately, are you using the same grade,
also how hot was the oil?
Fresh oil, same grade as always
Oil was as hot as it gets when car is fully warm...actual temperature not known
Point is, 2 months ago with this same scenario, I would get 15 psi higher readings on average
Re: (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">Fresh oil, same grade as always
Point is, 2 months ago with this same scenario, I would get 15 psi higher readings on average</TD></TR></TABLE>
My oil pressure dropped about 5 psi in the past few months, but its also been warming up outside... The hotter the weather gets your oil pressure will drop a bit.
Also the harder you drive the car, the lower the pressure will go,
When I was on the track I would drop from 75 psi to around 45 or 50!
I had to stop and it cool off for a while, and I should have changed oil grade.
My oil pressure dropped about 5 psi in the past few months, but its also been warming up outside... The hotter the weather gets your oil pressure will drop a bit.</TD></TR></TABLE>
I agree, but last august when I was running same grade oil, I had 100 psi at startup, and a constant 75
Its not oil grade...its not the heat...there is more going on...and I will find out what it is!
Re: D16y8-low oil pressure? (civic-4-ges)
Im running a turbo y8 and my guage at first start up is like 80-85psi.. After running it and then idle is around 9psi.. Cruzing at a normal 65mph its like 65psi.. Let off the gas and its around 46psi..Under boost load at WOT its like 85+.... I hope Im ok too..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">Well I tried some 10W30 last night, helped a bit. Temporary fix to a bigger problem I guess</TD></TR></TABLE>
"DO IT!"
"DO IT!"
Re: D16y8-low oil pressure? (LSVTEC 91 Civic)
"DO IT!" </TD></TR></TABLE>
BAH!
BAH!
Re: (civic-4-ges)
hey i was wondering where do u check for low oil pressure on a d16y8 b/c i have a feeling that i have really low oil pressure and i dont kno where to check for it thanx
PA MATT
04-11-2005 11:29 AM
