D16y8 Block Vs. D16z6 Block? whats the differance?
Old Jun 8, 2003 | 11:48 AM
bluedelsol's Avatar
Default D16y8 Block Vs. D16z6 Block? whats the differance?
I'm gona build the a "panda" D series engine vary soon, but i dont know what block i should use.
I found a post on http://www.Dsreies.org about a z6 head vs. a y8 head, but nothing on the block.
what block is better for boost? whats the diffeance between the two?
Old Jun 8, 2003 | 12:35 PM
BluntMan's Avatar
Default Re: D16y8 Block Vs. D16z6 Block? whats the differance? (bluedelsol)
i think the blocks are about the same but im not positive on that. the only difference i can think of right off hand is that the z6 head has a squared off chamber and the y8 head has a round chamber. z6 is 34.6cc and y8 is 32.8cc.
Old Jun 8, 2003 | 12:37 PM
RyanEJ8's Avatar
I can't think of any differences except for the pistons on the Y8 have a little more compression. Dome displacement on the Z6 is -10.10 cc per piston and -6.20 for the Y8. The bare block and crank should be the same.
Old Jun 8, 2003 | 01:57 PM
FFormula1's Avatar
I think the dipstick tube location is the only difference; thusly the Y8 would be a little more convenient if you wanted to get creative with the manifold and turbo location.
Old Jun 8, 2003 | 05:20 PM
turbo sol's Avatar
Default Re: D16y8 Block Vs. D16z6 Block? whats the differance? (Muffin')
to correct one of the previous post, the y8 has the square combustion chambers the z6 has round ones.
Old Jun 8, 2003 | 05:49 PM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
Default Re: D16y8 Block Vs. D16z6 Block? whats the differance? (BluntMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluntMan &raquo;</TD></TR><TR><TD CLASS="quote">i think the blocks are about the same but im not positive on that. the only difference i can think of right off hand is that the z6 head has a squared off chamber and the y8 head has a round chamber. z6 is 34.6cc and y8 is 32.8cc. </TD></TR></TABLE>
*ah ahem* got it twisted
z6 has the round chamber and y8 has the square chamber
Old Jun 8, 2003 | 06:46 PM
D-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muffin' &raquo;</TD></TR><TR><TD CLASS="quote">I think the dipstick tube location is the only difference; thusly the Y8 would be a little more convenient if you wanted to get creative with the manifold and turbo location.</TD></TR></TABLE>
The dipstick is in a diff location because of the oil pump..you could use the Y8 oil pump on the Z6 to move the stick...The Y8 has an extra sensor hole on the back side of the block for a knock sensor.
Novtec4u
Jun 15, 2009 09:05 AM
dohdoh420
13
Oct 27, 2005 12:33 PM
ArchAngel Sabastian
15
Dec 29, 2003 11:04 AM
milruner
Dec 29, 2003 07:13 AM
Red_Si
Jul 4, 2002 12:07 AM
