D16A6 Block Question
Old Apr 10, 2006 | 07:39 PM
Musicman22's Avatar
Default D16A6 Block Question
I have currently disassembled my d16a6 engine, i have measured the cylinders and found out that the cylinders are out of round and tapered.
i called a machine shop to ask how much it was to re-bore the cylinders bigger and they recommened simply re-ringing the motor.
I was wondering if this was a better way to do my re-build or if i SHOULD re-bore and get new cylinders. Any info would help greatly, Thanks
Old Apr 10, 2006 | 11:20 PM
ED7's Avatar
ED7
Default Re: D16A6 Block Question (Musicman22)
If they are out of round and tapered beyond specs, then you definitely need to overbore. The most you go is 0.5mm. Or you can go 0.25mm.
Old Apr 11, 2006 | 11:23 AM
Musicman22's Avatar
Default Re: D16A6 Block Question (ED7)
If i re-bore i will have to go to .050mm, but the machine shop said that i can simply re-ring..... i don't understand thier logic.
Any info helps
and thanks again
Musicman22
Apr 10, 2006 07:56 PM
boostedlude01
Mar 25, 2005 08:41 AM
underpressure02
Feb 19, 2003 05:18 AM
zdr262
Oct 29, 2001 10:44 AM
