d16a block w d16y8 head need some help
Old Mar 12, 2010 | 05:22 AM
1991SiCivic's Avatar
TRIAL USER
Default d16a block w d16y8 head need some help
Ok well i've done alot of reading now i need to ask. I have a 91 civic si i took the stock head off that is non vtec and put the d16y8 vtec head on. i used the stock head gasket along with all my stock intake, header, dizzy. now prob the timing belt isn't tight. from what i read the d16z6 is the best belt or is it the ten pully that i don't seem to know how to move. i left the bottom timing cover on. also can i run my stock ecu and everything i listed and just run an rpm switch for the vtec. and is the d16z6 intake better the my stock d16a if so i can get one cheap. let me know i can't wait to get this frankin up and racing.
Old Mar 12, 2010 | 06:34 AM
SpadedEK's Avatar
Default Re: d16a block w d16y8 head need some help
d16z6 intake manifold? better than an d16a, yes it is. but if you already have a y8 head why would you be using a z6 intake manifold
Old Mar 12, 2010 | 09:04 AM
TRIAL USER
well i bought just the head. and put all my stock d16a parts back on it. i just know where i can get a d16z6 intake.
Old Mar 13, 2010 | 07:18 AM
SpadedEK's Avatar
and i would prob run a vtec ecu and not use a garbage vtec switch
Singlebangin94
Mar 31, 2023 08:11 AM
1SikEagle
18
Sep 20, 2009 08:14 PM
dee16z6
Feb 12, 2006 01:30 PM
inane
Nov 10, 2004 07:59 PM
